Newbie jointer question
Forum topic by Pitt posted 84 days ago 425 views 0 times favorited 14 replies Add to Favorites
View Pitt's profile
Pitt
8 posts in 288 days
84 days ago
I just bought a Delta 6” benchtop jointer. I set it up, ran through some practice pieces and found that I was getting what appears to be an uneven cut. It’s more noticeable when surface planing a piece, but I end up with a deeper cut on the side away from the fence.
The obvious answer would be the infeed or outfeed table is tilted, but it doesn’t seem to be. Is there a tried and true method for setting up a jointer? Could technique affect this?
Thanks
View lew's profile
lew
1232 posts in 236 days
84 days ago
You could check the relationship between the table and the blades, across the width of the table.
Use a straight edge- 2 ft level or similar, and set it on the outfeed table- near the fence- so that it over hangs the opening between the infeed and outfeed tables. Rotate the cutter head by hand and see if any of the blades hit the underside of the straight edge. Adjust the outfeed table so that the blades just kiss the underside of the straight edge. Now, move the straight edge across the table so it is positioned near the blade guard. (It is helpful to clamp the blade guard “open” for the entire setup process). Rotate the cutter head by hand again. If everything is parallel, the blades should just kiss the underside of the straight edge on this side of the table, also.
If you find that the blades touch on one side but not the other and that the two tables are parallel. Then the blades need readjusted. There are several web sites that discuss how to setup jointer blades. I found several when Googling “setting up jointer blades”.
Lew
View Pitt's profile
Pitt
8 posts in 288 days
79 days ago
Thanks Lew
I adjusted the blades but am still getting the offset. I then set the depth to zero, so the infeed and outfeed tables should be even. They are at the fence side, but the infeed is a bit lower on the other side. Now trying to figure out how to adjust the jointer bed.
Pitt
View tenontim's profile
tenontim
913 posts in 225 days
79 days ago
Pitt, if the jointer is new and the tables aren’t level, I’d take it back to the merchant and get another one. That one may have been dropped or something. Like Lew said, if you checked the blades and they’re adjusted correctly, something is out of wack that you could spend a lot of time trying to fix.
-- Tim -- http://tmuli.com
View Pitt's profile
Pitt
8 posts in 288 days
79 days ago
thanks – I think I’ll do that
View Zuki's profile
Zuki
849 posts in 558 days
79 days ago
Hmmm . . . I believe that a few other Jocks has similar probles with Delta jointers. If you search the site you may find it. Better yet . . . do like tim said . . . return it for another.
View lew's profile
lew
79 days ago
Pitt,
Just spent some time at http://www.dewaltservicenet.com/ . You need to sign up but it is free. I looked up your jointer and there doesn’t seem to be any “normal” adjustments for this. However, from the exploded view, it appears that the supports holding the infeed and outfeed tables are bolted through the sides of the jointer. Perhaps they could be loosened and the adjustments made that way.
Time had a good point. If it is new, maybe you should contact the vendor for a replacement.
Lew
View Pitt's profile
Pitt
8 posts in 288 days
79 days ago
My thanks to everyone for their suggestions.
Everything was tight – I think returning it is the best option. Any suggestions on something a step up from this? I’ve also struggled with the age-old question of jointer v. planer…
Pitt
View lew's profile
lew
79 days ago
Pitt, I am not sure where you are located but if I was going to buy another jointer, I would look here first http://www.grizzly.com/products/searchresults.aspx?q=jointer.
Grizzly sells some good stuff at a great price.
As far as jointer vs. planer, you can plane on a jointer and joint on a planer. It just takes extra steps when you only have one and there are a few size constraints for your materials.
Lew
View brunob's profile
brunob
1389 posts in 650 days
79 days ago
I’d vote for Grizzly as well. I have their 6” jointer and it works great.
-- Bruce from Central New York
View Dusty56's profile
Dusty56
1159 posts in 169 days
78 days ago
You mentioned Delta benchtop jointer…is it the variable speed model ? if so , get your money back and step up to ANYTHING else…Stupid me kept mine long enough ( warrantee expired ) and made countless adjustments to try to get it to do what we buy jointers for , all the while blaming my newbe self for the problems only to find out that it was / is a piece of junk and doesn’t even make a good boat anchor (I’ve tried it ) I bought mine at least 10 years ago and I can’t believe they still keep making them with out fixing the problems !!! It has been collecting dust now for about 9 years I guess. I was going to tag sale it , but I’d hate to know that someone else would be cursing me for selling it to them .
-- Dusty56@comcast.net
View flink's profile
flink
95 posts in 201 days
58 days ago
Yeah, I’ve been eyeing a 6” grizzly. There’s a tent sale in September, too.
-- Made lots of sawdust and pounded some nails. Haven't finished anything, though.
View motthunter's profile
motthunter
1215 posts in 280 days
58 days ago
I got my 8” one at a grizz sale.. It was a great deal,, next itme I have to change the blades, I may upgrade to the spiral cutter heads…
-- making sawdust....
View Woodshopfreak's profile
Woodshopfreak
329 posts in 223 days
52 days ago
I saw another review like this that I read mabye its a a maufacture problems you can see it here
-- Tyler, Illinois
View Pitt's profile
Pitt
8 posts in 288 days
52 days ago
Thanks all. I returned the jointer and bought a planer instead – love it
Bookmark And Share This Page
