Need 1 1/4" diam x 51 hard wood dowel
Forum topic by EricTy posted 07-13-2012 12:11 PM 1136 views 0 times favorited 8 replies Add to Favorites Watch
View EricTy's profile
EricTy
62 posts in 2121 days
07-13-2012 12:11 PM
Topic tags/keywords: dowel
Hey All,
I’m in need of a 1 1/4” diam x 51” long hardwood dowel. I redid a closet and used a piece of, don’t laugh too much, pine. Now it’s laughing at me (or at least smiling) under the weight of clothes.
I’m just outside of Phila on the NJ side. Can somebody let me know if they can whip something up?
Thanks!
-- Only you know the mistakes were intentional...
8 replies so far
View mondak's profile
mondak
71 posts in 2271 days
#1 posted 07-13-2012 12:19 PM
Make a hanger bracket, with a cleat fastened to the back wall and center it on your pine rod. That will take the smile out and you should be good to go.
EricTy
#2 posted 07-13-2012 01:01 PM
I was trying to avoid a center bracket, but I think I’ll do something. Thanks!
View Bertha's profile
Bertha
13495 posts in 2564 days
#3 posted 07-13-2012 01:04 PM
Aside from metal or some incredibly expensive hard exotic, I’m not sure you’ll ever be happy with a wooden dowel across that expanse. I’d second the vote for the center bracket. I know, I know; I hate those things, too. But you can’t go with a diameter bigger than the inside of a coathanger, right? Good luck!
View Brandon's profile
Brandon
4152 posts in 2822 days
#4 posted 07-13-2012 01:09 PM
That is a bit long for a dowel—you can always go with a steel rod if you don’t like the idea of a center bracket. It’d be more expensive of course.
-- "hold fast to that which is good"
View Sawkerf's profile
Sawkerf
1730 posts in 2939 days
#5 posted 07-13-2012 01:29 PM
You should be able to buy a shelf support with a “hook” for a clothes rod. I just demo’d a closet and tossed one in the dumpster. Try any big box or hardware store.
View crank49's profile
crank49
4028 posts in 2842 days
#6 posted 07-13-2012 02:36 PM
Use a piece of 1” EMT (electrical metalic tubing) also known as thinwall conduit.
This is the correct diameter, is thinwall tubing so not too heavy, and comes in 10ft lengths.
Plus, it is electro galvanized so it won’t rust.
Can be cut to length easily with a hack saw or tubing cutter.
Or, the store might cut it for you.
View MNgary's profile
MNgary
296 posts in 2288 days
#7 posted 07-16-2012 04:31 AM
Maybe paint a section of galvanized pipe?
-- I dream of the world where a duck can cross the road and no one asks why.
View Jim Finn's profile
Jim Finn
2592 posts in 2793 days
#8 posted 07-16-2012 09:58 PM
I bought painted metal closet rods at Lowes .
