Finish for Mahogany Cross
Forum topic by Hrolfr posted 140 days ago 102 views 0 times favorited 3 replies Add to Favorites
View Hrolfr's profile
Hrolfr
99 posts in 203 days
140 days ago
I did a blog yester day about the Cross I am making for my father in law, I have made the prototype in pine
but the Cross I am going to give my F-I-L is going to be mahogany I went to woodcraft for some help picking out a finish they sugested a wipe on poly
only I got the satin… do you guys think this will look good or should I use another finish???
-- Hrolfr
View Russel's profile
Russel
1321 posts in 476 days
140 days ago
Wipe-on satin poly is my favorite. I typically seal with a coat of shellac first. Then 3-4 coats of wipe-on poly and I like the way it looks.
View EdC's profile
EdC
427 posts in 377 days
140 days ago
That should work really well. That and it’s super easy to use.
Just remember to take your rags and lay them out to dry outside, so you don’t have a unwanted shop fire.
-- Ed Collinge- Edmonds, WA.
9878 posts in 359 days
140 days ago
This finish will look just fine for mahogany. I agree with Russel that this is my favorite finish as well although I tend to go with the gloss.
But as far as the wipe-on product goes buying it is fairly expensive. Wipe-on poly is simply poly that has been cut with mineral spirits. You can easily make your own. I generally make mine up between 50 and 75 percent poly. Then simply apply as many coats as you want. If you want an even faster drying finish then you can dilute straight poly with lacquer thinner.
Bookmark And Share This Page
