Table saw for sanding?
Forum topic by Brickman posted 07-12-2012 04:39 PM 5415 views 0 times favorited 17 replies Add to Favorites Watch
View Brickman's profile
Brickman
51 posts in 2368 days
07-12-2012 04:39 PM
I was wondering what the opinion would be of using my table saw for sanding. I was looking around some sites today and came across Infinity Tools sanding disk for table saws. Table saw sanding disk
This got me thinking as I have a Grizzly 1023z and it would save valuable space in my shop. Anyone see any problems with this? I would have a huge tabletop surface and it already has dust collection hooked to it. Plus a 3HP motor. Only concern might be arbor bearings and such. So what do you think?
Mark
-- Mark - Pueblo, Colorado
17 replies so far
View Bill White's profile (online now)
Bill White
4929 posts in 3957 days
#1 posted 07-12-2012 04:54 PM
I have a sanding disc that you can buy. Also use it for set-up, and has some extra sanding paper. Just don’t use it. PM if you’re interested. $15.00 + shipping.
Bill
-- bill@magraphics.us
View richgreer's profile
richgreer
4541 posts in 3071 days
#2 posted 07-12-2012 04:54 PM
I’m concerned that your TS will be spinning at a much faster speed than is optimal for sanding. I have variable speed on my disk sander and speeds of about 1000 rpm just feel right. Your TS is probably spinning between 3500 and 4500 rpm. Too fast.
View bondogaposis's profile
bondogaposis
4727 posts in 2348 days
#3 posted 07-12-2012 05:01 PM
I’ve done it and I don’t use it too much unless there is absolutely no other way. For one it is a pain to replace the saw blade and sanding disc every time you to sand or cut wood. Then the speed is way too fast for optimal sanding. But I do use it on occasion, it is good to have options.
-- Bondo Gaposis
View brianinpa's profile
brianinpa
1812 posts in 3720 days
#4 posted 07-12-2012 05:16 PM
I have a 10” Craftsman Table Saw and I have a 10” disc sanding “blade” bought from Sears. Works terrific! Give me a large work surface and both sides of the “blade” have different grit sandpaper.
View fussy's profile
fussy
980 posts in 3048 days
#5 posted 07-12-2012 11:07 PM
Same as Brianinpa except mine is a 9” Craftsman bench saw with a 9” disc. One side is totaly flat and the other has a slight taper/ I use only the flat side and it works fine. The dc hooked to the saw catches most of the dust. Psa discs can be a booger to remome so I use a heat gun when it’s time to change. Comes right off. Highly recommend.
Steve
View AHuxley's profile
AHuxley
653 posts in 3318 days
#6 posted 07-13-2012 12:22 AM
I am not a fan of them, tool little room to sand (small disc and low height) and it spind WAY to fast for a sander.
View IrreverentJack's profile
IrreverentJack
727 posts in 2840 days
#7 posted 07-13-2012 02:21 AM
I’ve been looking at the Ridgid Sanding Wheel for a while now, but I haven’t needed it yet. Looks like the price has gone down a little. They are a lot cheaper. I don’t know if they work as well as the pricey ones. -Jack
View MonteCristo's profile
MonteCristo
2099 posts in 2185 days
#8 posted 07-13-2012 03:49 AM
Might come in handy for a specific job but I would not use it as my main disc sander for reasons already stated.
View PaulHWood's profile
PaulHWood
434 posts in 2250 days
#9 posted 07-13-2012 12:30 PM
Wouldn’t this be the same reason not to use a drill press as a sander. Putting force on the blade in a direction that is unintended?
-- -Paul, South Carolina Structural Engineer by trade, Crappy Woodworker by choice
View Bertha's profile
Bertha
13528 posts in 2690 days
#10 posted 07-13-2012 01:02 PM
I’ve seen these things and for some reason that I can’t define by science, it just seems like a really bad idea. Does it stress the arbor applying pressure from the side? How fast is that sucker spinning? What happens if something gets sucked down in there? Do you need to make a special ZCI?
Like I said, I don’t know.
View Knothead62's profile
Knothead62
2584 posts in 2958 days
#11 posted 07-13-2012 05:16 PM
I bought a sanding disk from Woodcraft. I use it a lot; limited to size of the wood, though. It has proven to be very handy. I even made a “jig” out of a piece of 1X2, drilled two holes in it and hold it down on the TS top with screws, washers and wingnuts. I square it up and sand away!
View Brad_Nailor's profile
Brad_Nailor
2539 posts in 3954 days
#12 posted 07-13-2012 05:40 PM
Has anyone tried out that sandpaper that attaches to the sides of your blade? Cut and sand at the same time..
View jackass's profile
jackass
350 posts in 3710 days
#13 posted 07-13-2012 06:04 PM
Hi;
I am not a fan of using my table saw for anything other than it’s intent, cutting wood. I have a sanding disk, scared to death of it, I also bought a ceramic tile cutting blade, both now sit in a drawyer and are never used, I used them once and am scared to death of them. The rpm’s of the saw are way too fast. Be careful if you want to try. A blade manufacturer produced a blade with sandpaper discs stuck on each side of a blade, it wasn’t on the market too long before it was discontinued, it was theoretically designed to sand both sides of a piece of wood to make it easier to join to another for gluing. I now use a “glue line blade” for this, great results.
Jack
-- Jack Keefe Shediac NB Canada
Brickman
#14 posted 07-13-2012 07:51 PM
Thanks for all of the replies. It sounded intriguing but I forgot about the RPM’s being so high. Plus this way I can justify to my wife the need for a dedicated sander. Thanks.
View Ristwood's profile
Ristwood
1 post in 1132 days
#15 posted 08-24-2015 05:42 PM
I make boxes and bought one not too long ago. For my work, I’m finding it a necessity. I bought the WoodTec tapered sanding disk and love the taper for my work… can do things I couldn’t with a straight disk. A lot of my boxes have tapered sides and/or ends so having the piece between the disk and the tablesaw fence is real handy. Boxes require precision on small pieces so this works great for me. One disadvantage for the average woodworker would be the size of the sanding area. But, that said, if you make small boxes like I do, it’s great and versatile.
-- Jim, Colorado
