Mineral Spirits and Poly Problem
Forum topic by BinghamtonEd posted 07-12-2012 04:22 PM 3311 views 0 times favorited 29 replies Add to Favorites Watch
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2365 days
07-12-2012 04:22 PM
Topic tags/keywords: question
So I went do to HD the other day, grabbed some Kleen Strip Oderless Mineral Spirits (NOT the green eco-friendly junk), and a can of MinWax oil-based poly. I mixed them 50/50 and put down a coat on some 1/2” dyed birch ply. When it dried, I noticed that the finish has spots in it of white. So I sanded down, did it again, same issue. So I put this finish on once piece, and then do straight 100% poly on another piece. Once its dried and hardened, I see the white spots in the piece with the mixture, and the one with straight poly looks fine. So I can reasonably assume that my poly is OK. Why would the 50/50 mineral spirits mix cause this? I’ve made wipe-on poly before and not had this issue.
29 replies so far
View A Slice of Wood Workshop's profile
1071 posts in 3169 days
#1 posted 07-12-2012 04:30 PM
Are they white spots or little air bubbles?
-- Follow me on YouTube- http://YouTube.com/user/asliceofwoodworkshop
#2 posted 07-12-2012 04:30 PM
Do you have any pictures?
BinghamtonEd
#3 posted 07-12-2012 04:38 PM
white spots, sorry no pics, will try to get some tonight. They’re just a flat dull white.
View bondogaposis's profile
bondogaposis
4723 posts in 2347 days
#4 posted 07-12-2012 05:05 PM
I try to stay away from Minwax. Is it possible that you may have introduced some contamination during the mixing process?
-- Bondo Gaposis
BinghamtonEd
#5 posted 07-12-2012 05:07 PM
I don’t think so, I mixed the poly in the can with a clean stir stick. I poured the poly and MS into a clean, dry plastic paint cup, mixed the MS in with the same stir stick. Straight poly coat came right out of the can.
View Mosquito's profile
Mosquito
9304 posts in 2288 days
#6 posted 07-12-2012 05:24 PM
Take a look at the Mineral Spirits, inside the jug/bottle. I had the same stuff, and at the bottom was a white milky (slightly thicker than milk) residue. Maybe you have some of that in yours, and it’s getting into the mixture? I’m not sure if it was there the whole time for mine, but I noticed it more once it started running out. I only used mine to clean up, though
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View dlmckirdy's profile
dlmckirdy
199 posts in 3129 days
#7 posted 07-12-2012 05:55 PM
I’ve had the same problems with Kleen Strip mineral spirits. I think it has to do with their low/no volitile hydrocarbon formula. I went to my LOCAL paint supplier and bought traditional miner spirits and solved the problems. The owner of the store/paint company said he gets the same complaints about Kleen Strip regularly.
-- Doug, Bakersfield, CA - I measured twice, cut it twice, and it is still too short!
View Mainiac Matt 's profile
Mainiac Matt
8034 posts in 2324 days
#8 posted 07-12-2012 06:03 PM
I think Doug is on the right train of thought….
“Odorless” mineral spirits can also be labeled “white” mineral spirits…. and I got a can a year ago that was just that…. white.
What Chris probably saw was a can that had been on the shelf a long time and whatever makes it white was settled down to the bottom.
I’m guessing that this stuff was tailored to artists and others who work with oil paints in doors and don’t like to stink up their studios with solvent smells.
Use that can to clean paint brushes and get some plain old, cheap and stinky “paint thinner”
+10 man points to Ed for not whimping out and asking for help (aka directions) untill after he botched the finish twice! Keep doin’ us proud brother :^)
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
BinghamtonEd
#9 posted 07-12-2012 06:09 PM
Lol thanks ssnvet. It’s my software engineering background coming into play ” “Huh, didn’t work? OK, try it again. Still no. OK, try it again. Still not working? ...”
View EPJartisan's profile
EPJartisan
1118 posts in 3121 days
#10 posted 07-17-2012 01:54 AM
Have you tried naptha? Mineral Spirits just has too much junk in it for me.. I only use it as a cleaner. Naptha mixes really well with Poly.
-- " 'Truth' is like a beautiful flower, unique to each plant and to the season it blossoms ... 'Fact' is the root and leaf, allowing the plant grow and bloom again."
View Ktrumble's profile
Ktrumble
17 posts in 1907 days
#11 posted 03-02-2013 12:50 PM
I think I am having the same problem. Did it look like this? Did you end up stripping it or applying 100% poly?
View camps764's profile
camps764
867 posts in 2356 days
#12 posted 03-02-2013 01:59 PM
yikes! That looks like a gorgeous piece Ktrumble – except that nasty spot.
Glad I read this thread…will keep using the stinky stuff.
I actually don’t mind the smell of mineral spirits – sort of like when i was a kid I loved the smell of gasoline…
which might explain some things about me I suppose.
-- Steve
Ktrumble
#13 posted 03-02-2013 02:12 PM
I too used the non stink min spirits. I also still like the smell of gasoline.
Ktrumble
#14 posted 03-02-2013 02:16 PM
Here is the rest of the table. I also learned that you really need to wait until Danish oil dries before applying poly. I had a ton of bubbling. We also had a lot of rain, so clearcoat took 3-4 days to dry. I hate finishing, but I can’t be impatient now after all the work I put into the piece.
Ktrumble
#15 posted 03-02-2013 02:20 PM
This one literally had blood, sweat, and tears in it. Stabbed myself with a chisel, causing three stitches. My wife didn’t understand why I stopped the bleeding, then immediately went back to the shop to scrub the blood off the table before going to the ER. I still can’t feel the end of my finger.
showing 1 through 15 of 29 replies
