what happened to my clear coat??
Forum topic by AKAndrew posted 07-12-2012 05:31 AM 1112 views 0 times favorited 4 replies Add to Favorites Watch
View AKAndrew's profile
53 posts in 2706 days
07-12-2012 05:31 AM
poly over oil stain. I stripped the old finish, left it for a few days, sanded with 120, then 220, brushed on oils stain, left it for 2 days, brushed on poly and now this???
View Ted's profile
2838 posts in 2142 days
#1 posted 07-12-2012 08:47 AM
Did you use alcohol or similar to thoroughly clean the wood after stripping it? If not, then the stain did not properly penetrate the wood, so the solvents in the poly dissolved the stain. Don’t ask me how I would know about that. :)
-- You can collect dust or you can make dust. I choose to make it.
View GrandpaLen's profile
1650 posts in 2203 days
#2 posted 07-12-2012 12:20 PM
You may have reactivated the residue of the stripping agent, if you didn’t get a thorough wash to remove the stripper. Unfortunately you will probably need to restrip the new finish and start again.
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View ZED's profile
83 posts in 2289 days
#3 posted 07-12-2012 05:15 PM
The poly obviously did not adhere to the wood. There are a number of reasons why this could have happened. The answer you’re looking for is what to do next. You’re going to need to strip it again and this time I would recommend using lacquer thinner after you have wiped the striper off. This works for both solvent-type strippers and semi-paste type strippers. Let dry. Then refinish. You could clean with Lacquer thinner twice especially if it’s an old piece that has been finished /refinished several times to get more of the old materials off. Hope this helps.
-- A good craftsman is able to make it work with the tools he has, I still need more tools
View Clint Searl's profile
Clint Searl
1533 posts in 2292 days
#4 posted 07-15-2012 01:26 AM
Strip with an MEC based stripper
Wash it down with naptha
Stain with a water soluble dye stain
