Workmate as Workbench Vise
Forum topic by Don Broussard posted 07-11-2012 11:28 PM 5073 views 0 times favorited 15 replies Add to Favorites Watch
View Don Broussard's profile
Don Broussard
3474 posts in 2158 days
07-11-2012 11:28 PM
Topic tags/keywords: question workbench
I built a workbench (http://lumberjocks.com/projects/64300) but since it has no vises, it is really a work table. I want/need to add more work holding capability and I was wondering if any other LJs have incorporated a Workmate (or something similar) as an end vise. I have seen others using pipe clamps as vises as well. I have a Wonderdog some hold downs on order to “hold” me over until I make more permanent provisions.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
15 replies so far
View dhazelton's profile
dhazelton
2689 posts in 2203 days
#1 posted 07-11-2012 11:33 PM
I can’t think how of how someone could incorporate the two, but people are resourceful. If you plane on doing some serious hand planing or chisel work I’d suggest adding some sandbags or other weight to the base of the Workmate for stability.
Don Broussard
#2 posted 07-11-2012 11:37 PM
I am thinking of dismantling a Workmate and reattaching the clamp to my work table. I was thinking that someone had already gone down this path. If not, I am not afraid to be a pioneer . . .
View waho6o9's profile
waho6o9
8100 posts in 2484 days
#3 posted 07-12-2012 12:49 AM
Nice workbench Don.
Attaching a workmate clamp to your workbench will be awesome.
View HerbC's profile
HerbC
1721 posts in 2766 days
#4 posted 07-12-2012 01:01 AM
I don’t know about your WorkMate but the one I have has plastic “nut” that after a little use fail to hold tite.
Good Luck!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
Don Broussard
#5 posted 07-12-2012 01:18 AM
Thanks for the comments.
I don’t actually have a Workmate, but I’ve been seeing a few of them on local CL postings. I just got to thinking that it might be possible to use its clamping ability and capacity on my bench. My bench is made of PT lumber, so if I plan to use a vise, I have to be careful about material selection. My dream vises would have wooden screws—I am actually looking at getting two of those.
@HerbC—Thanks for the information about the plastic nut. Maybe the Workmate is not the best idea after all . . .
View SamuelP's profile
SamuelP
793 posts in 2553 days
#6 posted 07-12-2012 01:21 AM
I would like to see it.
-- -Sam - FL- "A man who carries a cat by the tail learns somthing he can in no other way" -Mark Twain
View gfadvm's profile
gfadvm
14940 posts in 2597 days
#7 posted 07-12-2012 02:48 AM
I built the Moxon type vise attached to the front of my bench (see my projects) and it sees a lot of use and has held up well. If I did it over I would use the ACME rod rather than the all thread for speed of adjustment (but I solved that problem by adding power to mine!).
View AndyDuframe's profile
AndyDuframe
48 posts in 3497 days
#8 posted 07-12-2012 03:14 AM
I have a workmate that I use all the time, but it’s quite a bit lower in height than any workbench I’ve ever built—which means I’ve never been able to use them together. If I had bench/table like yours (which is nice by the way), I’d probably just stock up on a few new clamps to serve the same purpose. Some of the newer clamps/widgets are awesome.
-- http://www.ezwoodshop.com
waho6o9
#9 posted 07-12-2012 03:44 AM
View MT_Stringer's profile
MT_Stringer
3154 posts in 3138 days
#10 posted 07-12-2012 03:46 AM
I have a Workmate 225. It is about 25 years old…maybe older. I can’t recall when I bought it…two wives ago I think! :-)
I don’t think it would work as a clamp. I usually clamp to firm and stop because I don’t want to break it.
I am in the process of building a new workbench.
This is the vise I am installing.
My blog with progress so far is located here.
Hope this helps.
Mike
View OnlyJustME's profile
OnlyJustME
1562 posts in 2284 days
#11 posted 07-12-2012 05:09 AM
Waho6o9 The first thing i thought when i saw that picture was the thumb getting smashed trying to use the quick release button. lol
I found my quick release vise at a flea market(swap meet) and payed $15.00 for it.
then a few years later i found the same model vise at a salvage/reuse store and payed $5.00 for it.
Only seen this type of vise 2 times in my life and in different states no less.
Just keep looking on CL, yard sales, swap meets and you’ll find what you need for a good price. You don’t have to be too careful what type of material it is. It takes a long time (decades) for PT to do anything that will affect performance on a vise and a bit of paint will prolong it even more.
-- In the end, when your life flashes before your eyes, will you like what you see?
Don Broussard
#12 posted 07-14-2012 01:42 AM
@gfadvm—I like your powered Moxon vise.
@MT_Stringer—That Eclipse vise looks like one of the ones I want/need.
@waho6o9—That “pipe clamp” vise looks interesting, but I want/need one with a dog on the movable jaw.
@OnlyJustME—I am thinking more and more that I’ll just get a “normal” vise and take my chances on PT’s aggressiveness to mild steel or cast iron.
View BHitt's profile
BHitt
2 posts in 796 days
#13 posted 12-19-2015 08:58 PM
I see I am a few years late responding to this thread, but maybe all you guys are still alive so what the heck. I too thought the Chinese knockoff Workmate I have would be a good thing to cannibalize for hardware. I performed radical surgery on one today and the twin screws are perfect for what I want. There is no plastic on mine:
I made my bench from an old laminated maple library table and built the base and tool tray out of poplar. Now I will use one of the old maple library table legs for a vise face along the front of my bench. I’ll drill two holes for the threaded rods to slide in and out of the bench top. (I just polyurethaned the bench so that’s why it’s sitting on blocks)
BHitt
2 posts in 796 days
#14 posted 12-19-2015 10:23 PM
Don Broussard
#15 posted 12-19-2015 10:27 PM
Nice improvisation and repurposing on the vise as well as on the library table.
I ended up building a leg vise on my bench and bought an old cast iron Columbian woodworking vise to use. I haven’t cleaned up and installed it yet though.
