Clamps: how tight?
« back to Hand Tools forum
Forum topic by Brett posted 317 days ago 988 views 1 time favorited 21 replies Add to Favorites Watch
View Brett's profile
Brett
603 posts in 855 days
317 days ago
When I use clamps to hold boards together while glue dries, should I snug up the clamps just enough to keep the boards from sliding around, or should I tighten the clamps until the skin on my palm rips off and the blood vessels in my forehead burst? (Hyperbole, obviously—but a serious question.)
-- More tools, fewer machines.
21 replies so far
View Gregn's profile
Gregn
1643 posts in 1155 days
#1 posted 317 days ago
I only tighten my clamps till I have a slight squeeze out of glue.
View Knothead62's profile
Knothead62
1697 posts in 1133 days
#2 posted 317 days ago
What Gregn said.
-- Regret- the feeling you get just after you do something really stupid.
View Sawkerf's profile
Sawkerf
1776 posts in 1240 days
#3 posted 317 days ago
Just tight enough to close any gaps and get fairly even glue squeeze out. Squeeze out happens when the wood surfaces make contact and the glue has nowhere to go. When you see it, you’re boards are where they need to be.
If you’re having to “grind” the clamps to close gaps, you need to improve your edge joining methods.
Just for grins once, I took two pieces of scrap that went together with an almost invisible joint and glued them together with no clamps. I just squeezed them together with my fingers, laid them down and left them overnight. The next morning, they were as solid as a clamped joint.
View Fuzzy's profile
Fuzzy
251 posts in 2160 days
#4 posted 317 days ago
I use Besseys’ & Jorgies … I tighten them by hand, as much as possible … some will say that starves the joint of glue … others have PROVEN that to not be possible using only human hand strength. Most glue manufacturers (at least quietly) agree that more pressure is better, but they hesitate to make that recommendation, because some folks would just go nuts. Basically, with tools & clamps available in all but the most elaborate shops, it is not possible to over tighten your clamps, and the thinner the glue line, the better.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View David Kirtley's profile
David Kirtley
1250 posts in 1170 days
#5 posted 317 days ago
Depends on the type of glue. Each will have it’s own recommendations.
4898 posts in 1819 days
#6 posted 317 days ago
How much pressure depends on the beam strength of the
boards you are gluing together. I have K-body clamps I
use and I crank them pretty hard. I bet most seasoned
woodworkers do as well.
Sometimes if the clamp is tightened real hard you won’t
be able to loosen it with your hands and I’ve used pliers,
which scars up the handle. I have also drilled the handles
of some of my clamps to stick a screwdriver through it
to apply pressure and/or loosen a tight clamp.
View TCCcabinetmaker's profile
TCCcabinetmaker
743 posts in 526 days
#7 posted 317 days ago
they call it tightening the clamps for a reason, tight, this will help make sure you have a solid board to board joint where the glue is in the wood, not a strange kind of glue weld where the glue fills the gap. Though you need not bust blood veins.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View pintodeluxe's profile
pintodeluxe
1756 posts in 985 days
#8 posted 317 days ago
I tighten them until the gaps are closed. With freshly jointed lumber and good pipe clamps, that is usually just good and snug.
In other words stop after your fingers blanch slightly, but before a pre-frontal anuerism.
View KenBry's profile
KenBry
449 posts in 619 days
#9 posted 317 days ago
Tight enough to close all gaps but not so tight that the excess preassure creates new gaps. Allot does depend on the type clamp you are using as well. Use caution in clamping pressure too. You can over due it and destroy a clamp.
-- Ken, USAF MSgt, Ret.
View HoosierDude's profile
HoosierDude
47 posts in 1187 days
#10 posted 317 days ago
Here’s information from Titebond’s Product and Application Technical Guide:
Appropriate clamp pressure is essential for a successful bond. We recommend
the following guidelines:
For softwoods (pine, poplar): 100-150 psi
For medium density woods (cherry, soft maple): 150-200 psi
For hardwoods (oak, birch): 200-300 psi
I used to clamp the heck out of everything, just shy or bleeding hands and ruptured blood vessels. That was before I had a decent table saw and/or jointer.
Now that I understand the virtue of a joint that lines up without gaps before clamping, I tighten until I have uniform squeeze out. Either way, I’ve never had a joint fail.
-- Paul Lyons
View Bill White's profile
Bill White
2608 posts in 2132 days
#11 posted 317 days ago
Not so tight that ya have blood explode from your eyes. ( I couldn’t resist.)
Just get an even “squeeze-out” with PVA glues.
Bill
-- bill@magraphics.us
View MonteCristo's profile
MonteCristo
2061 posts in 360 days
#12 posted 317 days ago
My understanding is that you can’t make them too tight by hand. But I also agree that if you have to squeeze like crazy to close gaps, you need to re-joint.
View Enoelf's profile
Enoelf
190 posts in 435 days
#13 posted 317 days ago
I agree with the suggestion of tightening to achieve a uniform squeeze out of glue.
I remember watching a woodworking video where the presenter showed that with a properly jointed edge, you can actually create a strong bond between two boards with just water. If your edges are clean, crisp, and smooth, it shouldn’t be necessary to burst any blood vessels or remove any skin.
-- Central Ohio, Still got 9 and 15/16 fingers!
#14 posted 317 days ago
It is true that if you joint your boards perfectly the boards can
just be glued and rubbed together to spread the glue. This
is an old method used in Japan and I’m sure many other places.
The old glues may leave less of a glue line though and of course
good clamping makes the glue line quite thin and even less
noticeable.
View dnick's profile
dnick
582 posts in 554 days
#15 posted 317 days ago
It’s pretty much like everything else in woodworking, you just develope a feel for it. Over time you learn from trial & error, you develope a rythum, a feel for what works. You can learn volumns from others, as I have, but the best teacher is your own experiance. Pactice, practice, practice. The most difficult part of woodworking for me, was & is, patience. Learn from everything you do.
-- dnick, North Hollywood, Ca.
