Makita 2040 Planer
Forum topic by dkrienert posted 312 days ago 709 views 0 times favorited 1 reply Add to Favorites Watch
View dkrienert's profile
dkrienert
10 posts in 644 days
312 days ago
Topic tags/keywords: planer
I recently bought an old Makita 2040 planer that needs some TLC. I’ve got a local machine shop turning new infeed/outfeed roller shafts (the bearings had worn all the way through and damaged the shafts), but my main problem is finding the inner screws which adjust the spring tension on the rollers. Makita must have two different versions of the 2040, because the parts diagrams I found on ereplacementparts.com & toolpartsdirect.com do not match my unit. In the online parts diagrams, they appeared to replace the inner and outer adjustment screws on my machine (inner adjusts spring tension and outer adjusts the height of the rollers) with a single threaded knob. Has anyone ran into this before? Does anyone still sell the inner and outer adjustment screws, or do I have to buy the adjustment knobs? If I have to buy the knobs, I fear that they will not work with the existing metal holders. In the online parts diagram, the metal holder (321945-2) and pin (256650-1) are listed as type 2, which makes me think there is a type 1 and that the parts are not interchangeable. Can anyone shed some light on this, or am I going to be making a return trip to the local machine shop for some custom parts?
1 reply so far
View wrenchguy's profile
wrenchguy
12 posts in 223 days
#1 posted 149 days ago
as of 12-19-12 it cost me 209.50 to have j.j. short recover makita 2040 feed rollers. i have a type 1 and had a hell of a time reinstalling them to factory specs. don’t over tighten roller pressure springs, u’ll burn up plain bearing. call me if u want tips or help. mike @ 50eight-33three-933six.
-- wrenchguy mike, nw indiana, armpit of the nation!
