How often you use tilt feature on disc sander
Forum topic by higtron posted 316 days ago 567 views 0 times favorited 14 replies Add to Favorites Watch
View higtron's profile
higtron
145 posts in 846 days
316 days ago
I makeing a disc sander thats powered by my lathe the sanding deck/dust collection is set at 90% to my 12” disc as I couldn’t figure out how to achieve the tilt, and dust collection in one design. So now that it’s 90% done I’m just currios how often people use thier tilt feature on thier disc sanders.
-- If I cut it too short I can scab a piece on, but if it's too long what do I do?
14 replies so far
87126 posts in 1745 days
#1 posted 316 days ago
I Hardly use the tilt feature at all . But it depends what your making or plane on making.
View Dusty56's profile
Dusty56
10513 posts in 1856 days
#2 posted 316 days ago
Next to never…..any angles that I’ve needed to sand in the past, I was able to just use my miter gauge : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
higtron
#3 posted 316 days ago
Thanks Jim&Dusty that was what I thought to, Jim I’m not sure what all I’ll use the disc sander for probably just fairing curves, circle jigs, scarf joints ect. Dusty a miter gauge would make a good feature, something to think about.
View Gregn's profile
Gregn
1643 posts in 1152 days
#4 posted 315 days ago
I rarely use mine, although there are those rare moments when it does come in handy.
View Don W's profile
Don W
9951 posts in 736 days
#5 posted 315 days ago
i’ve had a home made disk for about 10 years, it doesn’t tilt and I’ve don’t beleive I’ve ever wished it did. I’ve got 2 other commercial models and I’ve never tilted either of them.
View gfadvm's profile
gfadvm
6626 posts in 858 days
#6 posted 315 days ago
Never tilted either one of mine.
Dusty56
#7 posted 315 days ago
Yes , make a miter slot across your table to fit one of your existing miter gauges and you should be set for life : )
View jumbojack's profile
jumbojack
681 posts in 792 days
#8 posted 315 days ago
When I first started to answer, I was like the others, rarely, but then I remembered fitting some dividers in some jewelry boxes, and cleaning up some mitered 45s and a few others. I suppose I could have used something else but there it was just asking me to tilt and sand.
higtron
#9 posted 315 days ago
This makes me feel better about my choice of no tilt feature on my disc sander, thanks for the responses.
View DrDirt's profile
DrDirt
1783 posts in 1911 days
#10 posted 315 days ago
I use mine when making lids and bottoms for shaker oval boxes.
The tops and bottoms are sanded to the line with about a 4-5 degree bevel. This makes the plates slip in tight like a cork in a bottle.
-- "_If we did all the things we are capable of doing, we would literally astonish ourselves_." Edison
View Dan Krager's profile
Dan Krager
714 posts in 402 days
#11 posted 315 days ago
Dr. Dirt raises a very good point. It’s pretty tough to sand the bevel on any curved piece using a miter gauge. If all your edges are straight…
You might get an idea for tilt from my loose tenon mortise jig posted on my web site blog
my blog
I’ve seen somewhere a hinged faux top that gets wedged up for bevels.
Dan
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com
Dusty56
#12 posted 315 days ago
You’d be better off making dedicated bevel “ramps” to place your stock on , if that’s all you sand that isn’t straight. My sander is a real bear to get reset to 90 degrees , so now that it is “perfect” , I leave it alone : )
View dbhost's profile
dbhost
4748 posts in 1400 days
#13 posted 315 days ago
I have a sanding disk I made for my lathe, with a flat table. No tilt. Don’t need it. But then again, I also have the Ridgid Oscillating sander. I honestly rarely use the disk… Sort of redundant.
Dusty56
#14 posted 315 days ago
I also made the lathe set-up and haven’t used it since getting my Ridgid sander.
