DIY wood kiln?
Forum topic by buckeyetd posted 318 days ago 1863 views 1 time favorited 6 replies Add to Favorites Watch
View buckeyetd's profile
buckeyetd
31 posts in 362 days
318 days ago
Topic tags/keywords: kiln home built home made drying wood milling
I’ve located a couple of sawmills that offer fairly cheap cypress in florida but the lumber is only air dried which is OK but it rains quite a bit in florida and the wood takes a while to dry out and I was wondering if anyone had a good idea for a home built of course low buck kiln? that would help resolve this issue. Thanks
I also read somewhere that cypress doesn’t do well in kilns.
-- http://www.gulfcoastchairs.com
View SASmith               's profile
SASmith
1368 posts in 1157 days
#1 posted 317 days ago
You could look into solar kiln plans. I bet you have plenty of sunshine where you live.
There are also plans around that use dehumidifiers.
-- Scott Smith, Southern Illinois
View pintodeluxe's profile
pintodeluxe
1754 posts in 983 days
#2 posted 317 days ago
If you have a small storage shed, it is easy to convert it into a kiln. I have turned small rooms into kilns by adding an electric heater, several box fans, and a home dehumidifier. Within 2 weeks I can take oak from 15% down to 6-8%, running the kiln at 100 degrees.
View crank49's profile
crank49
2288 posts in 1141 days
#3 posted 317 days ago
http://www.woodworkingtalk.com/f23/small-wood-drying-kiln-plans-dry-your-own-lumber-3103/
This is a link to another forum where a guy has been selling kiln plans for about 5 years. Must do something correct or it wouldn’t have been there for so long, IMHO.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View gfadvm's profile
gfadvm
6643 posts in 860 days
#4 posted 317 days ago
I stack and sticker mine in the attic of my shop. Amazing how hot and dry it is up there (and it doesn’t cool off a lot at night).
buckeyetd
#5 posted 317 days ago
Thank you everybody, great info.
View HalDougherty's profile
HalDougherty
1820 posts in 1407 days
#6 posted 317 days ago
I’ve been using the attic of my farmhouse for over 5 years to dry lumber to make gunstocks. The farmhouse is almost 100 years old and is uninsulated so it gets hot in the day and cools off at night. Just like a gentle solar kiln. This time of year in Tennessee air dried lumber goes down to 6 to 12% in less than 30 days. Virginia Tech has a great website with plans to build a solar kiln. You can size it just about any size you want. PDF files are on these VT sites.
http://sbio.vt.edu/about/extension/vtsolar_kiln
http://pubs.ext.vt.edu/420/420-030/420-030.html
I’ve also heard great things about Darren Nelson’s dehumidification kiln plans. He’s a member here so do a search for him and send him a note to ask any questions you have.
http://nelsonwoodworks.biz/pb/wp_395bc3fb/wp_395bc3fb.html
You can also find a lot of good information on this site about solar and dehumidification kilns on this site.
http://www.allwoodwork.com/article/woodwork/solarkiln.htm
You can also search Google and you’ll find more information than you will have time to read.
-- Hal, Tennessee http://www.first285.com
