| Forum topic by dennis62 | posted 317 days ago | 724 views | 0 times favorited | 11 replies | ![]() |
317 days ago |
I am going to be moving my shop to a bigger location. Problem is the new site has no floor. Just gravel. I live in a mobile home park and to put in concrete would require me to tear down structure and start over. I was thinking of a wood floor. Something like this. First, lay down some 1/4” high density foam with 4 or 6 mil plastic over that. Then just put down 3/4” ext ply with tonge and groove, glued at all the joints. A floating floor on grade. Any thoughts, ideas. Also, if you live in the pittsburgh area and looking for something to do, I could sure use some help. |
11 replies so far
#1 posted 317 days ago |
Seems like it would work. I’m not sure if it makes any difference, but you may want to consider placing the plastic on the gravel before the foam… I’m thinking that would keep ground moisture from contacting the foam and further away from the wood, but you risk poking holes in the plastic with the gravel if you do that. -- The Dude abides |
#2 posted 317 days ago |
Could you add treated sleepers under the plywood? Maybe treated 2×4s? Then you can fasten the plywood down, makinf it one big, solid floor. Plastic on top of the gravel, and fill in the spaces between sleepers with foam board. Be sure to compact the gravel before you start anything else. Just get the gravel level and well compacted, just like you were going to pour a floor. Tape the seams on the plastic, as well. -- A Planer? I'M the planer, this is what I use |
#3 posted 317 days ago |
Welcome to LumberJocks Dennis! Good luck on your move and may you have continued success. |
#4 posted 317 days ago |
Dennis here is what I’d do, dig down below grade into the dirt I’d say about 6 inches the whole complete area, getting the gravel out, bring in center blocks space them about 3’ apart in rows, level and plumb them and then lay a 2×4’s edge way frame for support (2×6s would be better though) on top of them then lay the wood flooring ply board on top of them. -- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs |
#5 posted 317 days ago |
Dennis, welcome to LJ. I don’t know the size of your shop or your budget. However, if I were doing your project, I would want to put down a good vapor barrier, insulation, tubing for radiant heat and finally, 3.5” concrete. The insulation keeps the heat in the building and that helps prevent your tools from rusting. You should be able to put the chute from the concrete truck through a door and wheel barrow the concrete where it needs to go. One yard will cover about 90 square feet @ 3.5” thick. It would also be good to have a step up into the building to keep any ground water out. FWIW -- Art |
#6 posted 316 days ago |
Wow. Five years with all the mag subscriptions and never a reply. This site is the best I’ve come across in a long time. |
#7 posted 316 days ago |
If its in a funny spot there has been a good amount of usage of “Gyp-Crete” being used in the commercial industry. From what i gather its a light weight blend of gypsum and concrete. I couldnt comment on the costs though. Welcome to the gang Dennis. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#8 posted 316 days ago |
Here’s a low tech suggestion: http://www.youtube.com/watch?v=d3M-GVdz1xo Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#9 posted 316 days ago |
Thanks Chrisstef, I’m going to look into it. I do have connections in the concrete industry if I can go that way. Waiting for my budy the landlord to stop by so I can sign off on something. |
#10 posted 316 days ago |
Gyp-crete is for leveling out existing slabs without adding to much extra wieght to the existing structure, it is not in any way structural and would crack and heave it’s not structual due to the fact there is no agrigate which gives concrete it’s strength and I’m not to sure it would save you any money. Gyp- crete is a money saver when you are trying to save yourself the cost of jacking out a slab and starting over. It’s used in comercal buildings mostly sometimes it’s used as a sound deadener over wooden floors. A vapor barrior of plastic sheeting and concrete would be you best bet and last for years to come just remember if you do it yourself it is very hard work and it’s turning into a large rock as soon as it comes off the truck and the hotter the day the sooner it tuns into said rock. good luck -- If I cut it too short I can scab a piece on, but if it's too long what do I do? |
#11 posted 316 days ago |
Mention to your landlord that a concrete floor (radiant heated?) will increase the value of his/her property and will increase the chances of keeping you as a long term tenant. Both will be more profitable in the long run for the landlord. -- Art |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3549 |
15781 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
