Mop sander
Forum topic by bullhead1 posted 07-08-2012 02:40 PM 4006 views 0 times favorited 5 replies Add to Favorites Watch
View bullhead1's profile
bullhead1
228 posts in 2272 days
07-08-2012 02:40 PM
I do some relief carving and just don’t like all the hand sanding. I’ve been looking at the sanding mops at Rockler and wonder it anyone has use one and if there worth the $$$$?
5 replies so far
View Raymond Thomas's profile
Raymond Thomas
189 posts in 2241 days
#1 posted 07-08-2012 03:42 PM
It depends on how deep and how aggressive you want to get with the relief you are carving out. If you are going deep, and if you have a 4-1/2” angle grinder – you might want to check out the “King Arthur Tools Lancelot Woodcarving Disc” at Woodcraft. They are available in 14 tpi, 18 tpi and 22 tpi. Being that they are made with a chain saw style cutting teeth – they can be resharpened very easily. Use the link below.
Chainsaw Carvers
-- Raymond, Charlotte, NC -------- Demonstrate the difference!
4998 posts in 2516 days
#2 posted 07-08-2012 06:11 PM
I bought a mop sander from Klingspor when I was putting in a new stair rail with about 130 balusters at our old house. These were stock (factory made) balusters I bought at HD, and I wanted them smooth for finishing (red oak). Chucked that sucker up in the drill press and started working on them….huge disappointment. It did very little to help take some of the roughness out of them, I wound up going back to hand sanding (ugh!) That mop is still in my danding supplies drawer, haven’t used it since (about 6 years ago).
View AHuxley's profile
AHuxley
663 posts in 3344 days
#3 posted 07-08-2012 06:21 PM
@Fred Even though you may only do it once balusters are really a “production” job. You needed the much larger heads designed for running on a fixed shaft, Klinspor makes some excellent ones, I think they start at about $100, the perfect tool would be a Sandrite or at least a Sandrite head but they aren’t cheap. One other consideration is the faster you spin any of these rotary sanding heads the higher the effective grit you have, the general rule is at least 1 grit down from what you would hand sand with, usually two.
117115 posts in 3600 days
#4 posted 07-08-2012 06:35 PM
I think this brush sander would do the job but it’s a lot more money than a mop sander.
http://www.youtube.com/watch?v=FNUH1uchnS4
View SASmith               's profile
SASmith
1850 posts in 3010 days
#5 posted 07-08-2012 08:54 PM
Not sure if this will work for you, but there are some DIY mop sanders on lumberjocks.
-- Scott Smith, Southern Illinois
