Finishing Beetle Kill Pine - What do you use?
Forum topic by camps764 posted 346 days ago 1435 views 0 times favorited 4 replies Add to Favorites Watch
View camps764's profile
camps764
383 posts in 557 days
346 days ago
I know there are a few guys on this site that specialize in Beetle Kill Pine (Blue Pine). I recently received an industrial sized pallet, much to my surprise, when I planed the saw marks off I found that it was actually beetle kill pine. I had been planning to order some from Colorado, so this was an awesome turn of events.
Now that I’ve picked out a project for the special wood I want to think through the finishing process.
What do the pros use as a finish? I want to preserve and pop the blue/purple color as much as possible while maintaining the contrasting white/yellow wood in the boards.
The boards will be used as a counter-top for a craft counter/computer desk.
I’ve thought about just using a wipe on poly cut with mineral spirits, but I’d like to see what other options (read better ideas) there are.
Any suggestions? I really appreciate anyone’s opinion/input!
-- - Steve Campbell
View GrandpaLen's profile
GrandpaLen
987 posts in 469 days
#1 posted 346 days ago
Camp,
Although I’ve not personally worked any Beetle Kill Pine maybe I can help by suggesting you visit the sites below, check out their sites and read the techniques used by these two Artisans.
RockyBlue
http://lumberjocks.com/projects/68133
-and-
Monte Pittman
http://lumberjocks.com/projects/67637
Work Safely and have Fun – Len
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
camps764
#2 posted 345 days ago
Thanks Len!
-- - Steve Campbell
View Durnik150's profile
Durnik150
647 posts in 1519 days
#3 posted 345 days ago
I would be stretching it to say I was a pro but I have worked with beetle kill pine a lot in the past. The biggest problem I had with finishing it was that it was a very “thirsty” wood and would suck up anything put on it. I discovered that using a pre-conditioner worked very well. It would get sucked into the wood and set up an inner layer that would keep the wood from sucking up quite as much as normal. The kind of pre-conditioner I used was an oil based one from General Finishes. I’m sure other brands work just as well but I was very satisfied with this one. After that dried (it is an oil based product so it takes a while) adding any final finish layers was much easier. I generally use a poly finish on top and it works well also.
I hope that helps.
-- Behind the Bark is a lot of Heartwood----Charles, Centennial, CO
View Monte Pittman's profile
Monte Pittman
7209 posts in 535 days
#4 posted 344 days ago
Rockyblue uses epoxy bar top coating on tables and UV resistant polyurethane on virtually everything else. I use the UV resistant polyurethane on everything at this point, but I want to switch to bar top epoxy also for tables & benches. It’s messy if not handled properly and my first go around I didn’t. Ugh! Rockyblue knows A LOT more than I do, but I’ll answer anything I can for you.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
