| Forum topic by chrisstef | posted 318 days ago | 573 views | 0 times favorited | 12 replies | ![]() |
318 days ago |
I had just sanded the dust nibs out of my first coat of arm a seal with 320 grit and like usual i grab The mineral spirits to remove the light sanding dust. I wipe the whole piece down and while im waiting for it to dry i read the can. Clean up – mineral spirits. Am i ruining the first coat by using the specified clean up solvent?? Should i just use a wet rag? -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
12 replies so far
#1 posted 318 days ago |
I believe that the label is telling you how to clean up “wet” Arm-A-Seal. |
#2 posted 318 days ago |
It hasnt seemed to have an effects but i figured id toss it around and check it out. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#3 posted 318 days ago |
If it’s dry enough to sand, you did no harm. At least you’re getting something done. Steve -- Steve in KY. 44 years so far with my lovely bride. Think I'll keep her. |
#4 posted 318 days ago |
Thanks Steve, i kinda thought so but the brain must have been hungry for an answer. Movin full steam ahead on the project. Maybe another week of finish and itll be done. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#5 posted 318 days ago |
2 words – Tack Cloth. That is the only thing I ever use to clean a finish after I sand or steel wool. One word of caution, it’s basically cheese cloth soaked in poly. If you are using a finish that doesn’t get along with poly, I’m not sure I would use one. |
#6 posted 318 days ago |
Yea i got annoyed with tack cloths. Got all gummy, held slivers, and cost too much for me personally. I may try making my own though. I was more curious about applying a solvent to remove dust that is intended to clean up or thin the finish. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#7 posted 318 days ago |
I may try making them. I have a jar I keep them in. They stay fresh. And if you are getting slivers when it’s finishing time, you need to spend some more quality time with your sander :) I’m sure it’s all in my head, but I don’t want to put something that I use to REMOVE the finish from my brushes on the piece I am trying to get the finish to stick on |
#8 posted 316 days ago |
Sounds like you could use an air compressa. Ah yet, thats what ya need, don’t ya know. Blow that sanding dust around a bit. (I’m over it now) -- Dan I.G.N. |
#9 posted 316 days ago |
Also Arm-r-seal is a great product, but the last time I was in woodcraft the guy talked me into a 26$ can of waterlox. I used some on a piece my wife is refinishing. I am never buying anything else now. |
#10 posted 316 days ago |
Dan, thats funny that Maine accent will stick with ya for some reason. Im glad i could help ya get that outta your system. I typically use the shop vac to remove the dust first then wipe it down with a rag and mineral spirits, let it dry, wipe down again, then proceed with usual finish. It was one of those Ah Ha moments as i was waiting for the spirits to dry when i was reading the can of Arm-A-Seal. It just got the wheels turnin a little bit and made me wonder if i was doing any damage to the finish. I really didnt think so but just as food for thought i figured id pose the question around here. Joe – i havent tried Waterlox yet but so far ive got one coat of Arm a seal on ambrosia maple and 2 coats on walnut and i like the stuff a lot. Finished pics of the coffee table arent too far out. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#11 posted 316 days ago |
Chris, I thought Arm-r-seal was the bees knees too – until I tried the waterlox. It’s so much easier to work with and get a nice finish, and to me, the finish looks a LOT nicer. Some people claim waterlox isn’t as durable of a finish, but I question that. It was originally intended FLOORS. I’m not sure where you would need a more durable finish than something you walk all over and drag furniture on. Also, I’m not sure if CT has gone the environmental Nazi route that MA has taken, but my woodcraft guy said they may stop carrying the regular Waterlox soon in favor of the low VOC version. From what I understand (and can confirm with other stuff like paint) low VOC stuff SUCKS. I can’t wait to see that table! |
#12 posted 313 days ago |
I just put on the last coat of finish last night. Tonight it will get a good coat of wax and final buffing. I should have it assembled and on display here rather shortly, probably this weekend. I ended up brushing on 2 coats and wiping on 2 more. Ill have to give the Waterlox a try sometime soon. It shouldnt be long until CT bans all the good stuff too lol. Might be time to stock up on the high test. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3549 |
15782 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
