Perfect inside corners... How??
Forum topic by DanoP posted 316 days ago 831 views 1 time favorited 14 replies Add to Favorites Watch
View DanoP's profile
DanoP
125 posts in 505 days
316 days ago
Topic tags/keywords: question
So… I’m trying to build my box making skills and I can get really nice mitered corners but find myself baffled trying to clean up the inside corners. Even taping and slitting the joints, I still find myself spending way too much time cutting, scraping and sanding that tiny bead of glue. Anyone out there have a good method for good CLEAN glue joints on small boxes? While I’m at it, how about sanding and buffing all the way to the edge in those bottom corners. I’d love for the insides of my work to look as nice as the outside.
Thanks in advance for your help.
Dano P.
-- We've got enough youth. Let's search for a fountain of smart.
14 replies so far
View KnickKnack's profile
KnickKnack
805 posts in 1732 days
#1 posted 316 days ago
I’m no expert but, as soon as the thing is glued up and clamped, I scape off those glue beads with a (fairly blunt) chisel while they’re still wet – that gets off a lot of it. And I’ve glued sandpaper (I use 180 for the insides) onto plywood to give me strips that can more easily get into those nooks and crannies.
-- "Do not speak – unless it improves on silence."
View Ted's profile
Ted
1400 posts in 377 days
#2 posted 316 days ago
I try to keep the glue more toward the outer edge. If any glue oozes out on the inside I clean it up right away with a wet rag, making sure to get all of it. I often use a putty knife to get the rag well into the corner, especially where it meets the bottom.
Once I’m sure I got all the excess glue out, I use a dry rag or rub it with some saw dust to dry it. The water raises the grain, but I would rather sand a little raised grain than sanding glue.
I tried taping off the wood but that just seemed to make more of a mess.
-- I'll grow up when ketchup bottle farts stop being funny.
DanoP
#3 posted 315 days ago
Thanks guys. I use a wet rag on the outsides of the boxes but my technique I’m using now (similar … Kinda, to Boxguy’s EZMiter) has me closing up the box till the glue dries then cutting the top off. I can’t get into the sealed box to wipe off the wet glue.
I eventually get the glue off using my marking knife and lots of time. Just hoping for an easier method. There might not be one and this may just be a drawback to this method.
That still leaves the second question. How do you buff and sand the inside corners to get them just as shiny and smooth as the rest of the box? The answer can’t be just cover it in velvet or suede. After hours of fussin and frettin, the bottom of the inside corners never look just right.
Looking forward to your replies.
Dano P.
View woody123's profile
woody123
40 posts in 1472 days
#4 posted 315 days ago
I found a quick way of cleaning the glue out of the corners by using a plastic drinking straw. I squeeze it a little to form a crease, then push it down the corner while the glue is still wet, scooping the glue up as I push it along.
I then clip the end of the straw that is full of glue,and keep on cleaning with the cleared end. It works like a charm.
KnickKnack
#5 posted 315 days ago
…using a plastic drinking straw
That seems like a pretty ace idea.
One other thing I do now, being a mathematician, is to put less glue on. The instructions always say something like – ”until a thin bead of glue squeezes out”. That was all glue that didn’t need to be there, so, it seems to me that if you’d put slightly less glue on, less would squeeze out, until you get to the point where none squeezes out but if you’d added more it would have done. As someone said somewhere else – it’s a box, no-one is expecting to be able to play football with it.
View waho6o9's profile
waho6o9
2881 posts in 743 days
#6 posted 315 days ago
Once I do a dry fit and everything is to my liking, I finish the piece with Watco oil and finish the project.
Then, I do the glue up.
Glue doesn’t stick to the finished project.
It’s a lot more work, but I think it looks better.
HTH
I don’t skimp on the glue, no sense starving the joinery.
View knotheadswoodshed's profile
knotheadswoodshed
85 posts in 338 days
#7 posted 315 days ago
I buff the insides of my boxes prior to assembly with tripoli and white diamond..up to the miter joint (not the miter itself) after the glue dries, I find that it peels off nicely, and still leaves me with a nice strong glue joint
-- Randy - "I dont make mistakes, I make design change opportunities" www.knotheadswoodshed.com
View Greg The Cajun Box Sculptor's profile
3762 posts in 1474 days
#8 posted 315 days ago
I put glue on the miters except for the last 1/16th of the inside. Usually any clamp pressure will add a wee bit of glue to this spot. This will not affect the joint but I rarely ever get squeeze out. As a precaution I also cover the edges of the inside miter with Frog tape prior to glueup.
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com
View ddockstader's profile
ddockstader
78 posts in 1427 days
#9 posted 315 days ago
One other trick – rub the insides of the box up to the miter with an old candle stub. The paraffin coating won’t allow the glue to stick and it can be dissolved (after you remove the dried glue) with mineral spirits.
View Dusty56's profile
Dusty56
10496 posts in 1854 days
#10 posted 315 days ago
Finish insides before assembly , taking care not to get any on the surfaces to be glued , and if you put a nice coat of wax next to the joints , the glue won’t stick : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View lumberjoe's profile
lumberjoe
2394 posts in 414 days
#11 posted 315 days ago
Dewaxed shellac. Glue won’t stick to it, virtually any other finish will
-- http://www.etsy.com/shop/KandJWoodCrafts
View Cato's profile
Cato
642 posts in 1478 days
#12 posted 314 days ago
I generally finish my inside before glue up and if the finish is shellac then glue won’t stick to it as Joe says.
If it is not shellac or is not going to get a finish after glue up then I will use tape like frog tape to keep the glue off.
View jmartel's profile
jmartel
55 posts in 316 days
#13 posted 312 days ago
When you glue it up, use q-tips dunked in water to clean up the wet glue. Once you get it all cleaned up, it will dry out and not have any finishing problems.
Dusty56
#14 posted 312 days ago
Please read his post …the box is closed until he cuts the top off !
