Want to build a steambox
Forum topic by Phil68 posted 07-06-2012 06:01 PM 1846 views 0 times favorited 9 replies Add to Favorites Watch
View Phil68's profile
16 posts in 2154 days
07-06-2012 06:01 PM
Just picked up the Earlex steamer. I’m gettitng ready to build a steam box. I have a 3’x8’x3/4” piece of Pressure Treated Plywood. Does anyone know of a reason why I SHOULDN’T use pressure treated plywood for the steambox? It’s what I have laying around so I figured I’d use it. Any input is greatly appreciated!!
9 replies so far
View Bill White's profile
Bill White
4880 posts in 3895 days
#1 posted 07-06-2012 06:50 PM
Don’t think the ply will take the moisture/heat w/o delaminating.
How much are ya planning to use the box? I’d try to find some white oak for the ideal, long-term box. Stainless steel screws to assemble. If short term use, just use poplar. Pine could get kinda messy if the rosin started to bleed.
View David Kirtley's profile
David Kirtley
1286 posts in 2933 days
#2 posted 07-06-2012 08:35 PM
Best steam box I know of is just taping one together from sheet foam insulation. Waterproof and makes the steam stay steamy longer. ;)
-- Woodworking shouldn't cost a fortune:
View Doss's profile
779 posts in 2199 days
#3 posted 07-06-2012 08:38 PM
Maybe combine David’s idea with your own idea. Build the box out out of PT ply and then line/seal the inside using foam insulation.
Worth a try?
-- "Well, at least we can still use it as firewood... maybe." - Doss
View Woodendeavor's profile
276 posts in 2542 days
#4 posted 07-06-2012 08:58 PM
My first stem box was built on a tight budget. I used a piece of 8” round duct work and made plywood ends for it. Lasted me almost 2 years using it on a monthly basis or more. It opened my mind to so many different designs. Good Luck
View TheOldTimer's profile
226 posts in 3021 days
#5 posted 07-06-2012 09:04 PM
I seen one built out of PVC pipe using end caps. Steam entered one end and exited the other. The door was a end cap with a handle attached. The oposite end was glued on with a small escape hole at the tip and a small drain hole at the bottom. I do not steam bend but if I had to build one I would try that design. Copper wire was used to elivate the material or wood off the bottom of the pipe. The pipe was drilled on the sides and the coper wire inserted at various points. The pipe size was 6 or 8 inch PVC.
-- TheOldTimer,Chandler Arizona
View Loren's profile
10107 posts in 3583 days
#6 posted 07-06-2012 09:06 PM
You can use the ply… you might paint or varnish the inside though.
Don’t expect the glues to hold up, but you may be surprised
at how long it lasts.
View DS's profile
2866 posts in 2355 days
#7 posted 07-06-2012 09:10 PM
My first steam box was a roll of flashing that I fashioned into a ac duct style box.
It worked pretty good.
View EPJartisan's profile
1118 posts in 3060 days
#8 posted 07-10-2012 08:57 PM
I made mine out of plywood.. things I discovered… need upper vents and lower drainage holes.. so I put mine on a angle… and be careful of the ply you use for defects and knot holes… for the heat may make any sap left in the plywood to leak out onto your work. Propane stove, aluminum pot, duct vent, and insulation foam to hold the door in place (which eventually melts and has to be replaced.. but I am a poor artist making out of what I can. lol)
-- " 'Truth' is like a beautiful flower, unique to each plant and to the season it blossoms ... 'Fact' is the root and leaf, allowing the plant grow and bloom again."
View kizerpea's profile
774 posts in 2303 days
#9 posted 07-11-2012 12:02 PM
e-mail shipwright hes the wood bender
