Quilt Rack Design Change?
Forum topic by gfadvm posted 07-06-2012 02:07 AM 1245 views 0 times favorited 10 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2653 days
07-06-2012 02:07 AM
Topic tags/keywords: quilt display rack
I’m in the process of building the quilt display rack from the latest issue of WOOD. I like the design but hate the allthread and acorn nuts. Does anyone see a problem with using 1/2” dowels and wedges rather than the allthread?
10 replies so far
View Gary's profile (online now)
Gary
9324 posts in 3396 days
#1 posted 07-06-2012 02:12 AM
Seems to me, that would be a better choice
View Monte Pittman's profile
Monte Pittman
28903 posts in 2301 days
#2 posted 07-06-2012 02:21 AM
In the name of woodworkers, I would think that is not only acceptable but would be the right thing to do. Hope you post it!
-- Mother Nature created it, I just assemble it.
gfadvm
#3 posted 07-06-2012 02:32 AM
I agree but was concerned that the arms not sag. I’ll do the wedged dowels and see how it works out. Monte- You know if I build it, I’ll post it! I can’t help myself.
View rance's profile
rance
4255 posts in 3124 days
#4 posted 07-06-2012 03:26 AM
I would advise but my copy is at the shop. Sounds like you have a good solution though.
View GrandpaLen's profile
GrandpaLen
1650 posts in 2236 days
#5 posted 07-06-2012 09:45 AM
I have that article in front of me and can’t, for the life of me, figure out why they used all thread instead of 3/8” hardwood dowel, unless they thought it would be easier for the DIY’ers to mount them that way, it’s certainly not due to the weight of one quilt, per arm.
IMHO, I’d cut the dowel to exact length and put a drop of CA GEL glue at the top of the dowel just as I slid it into place, that should hold it, unless the grandkids do chin-ups on your rack. :-)
Work Safely and have Fun. – Len
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View HalDougherty's profile
HalDougherty
1820 posts in 3200 days
#6 posted 07-06-2012 11:11 AM
I’m building the same project. My first thought was to use brass acorn nuts and add a piece of copper waterpipe to reinforce the wood parts so the threads don’t wear out the hole too quickly. Only one problem… Home Depot had steel acorn nuts, but at a cost of $1 each! Nope, spending $8 per quilt rack for acorn nuts, is just nuts… My plan is to use a 3/8” dowel with a turned knob on top to hold my maple hinge pin in place so it will be removable for packing and shipping. I’m also going to make one with shorter arms to use as a towel rack in the bathroom. Looks like it’s going to be a race to see who posts the first project here on Lumberjocks.
-- Hal, Tennessee http://www.first285.com
View Roger's profile
Roger
20923 posts in 2767 days
#7 posted 07-06-2012 01:21 PM
I’d just use a thicker dowel…... ?
gfadvm
#8 posted 07-07-2012 12:46 AM
Hal, Mine is built with 2 coats of finish so far! I used 1/2” dowel split and wedged with Jatoba wedges. I had another thought that would completely hide the dowel or even metal pins (just drill partway through the ‘brackets’ and sandwich the pin between them). Is there a prize for the first posted here?
HalDougherty
#9 posted 07-07-2012 08:31 PM
Mine would be finished, but the board I used was knotty (or it would be a gunstock) and I filled the holes with epoxy and let it dry for 24hours. I’m going to use a 7/16” dowel (cause that’s what I have on hand) and put a small wedge in the top only so I can drive the pin out if I ever need to.
gfadvm
#10 posted 07-08-2012 12:46 AM
Hal, You’re behind. I cut out and routed all the parts for my second today:>)
