| Forum topic by fullcity | posted 320 days ago | 694 views | 0 times favorited | 11 replies | ![]() |
320 days ago |
Hi all, The motor on my HF DC seems to be DOA – won’t turn on. In the mean time I purchased a replacement unit (easiest way to get the DC up and running on a Sunday afternoon) but I’d still like to replace/repair the shot motor and have a second DC. Any suggestions? The replacement motor from HF was ~$95. Having never had to deal with replacing/repairing a motor before I’m looking for advice on the most cost effective (aka “cheapest”) way to get the 2d DC up and running. Thanks, -- Adam - Red Hook, NY |
11 replies so far
#1 posted 320 days ago |
“Won’t turn on” could be any number of things! I’d pull out the meter and start troubleshooting before I go out buying a new motor. See if you have power on both sides of the switch when you turn it to the “on” position so you can rule it out. Check that you have voltage at the motor to rule out wiring, etc.. I don’t know if that unit has any circuit protection, but if it does, check on both sides to make sure it’s working. If it really is the motor, those can be fixed as well depending on what is wrong.. which means you gotta yank it apart and find out first. Might be something as simple as a worn/broken brush or spring. Cheers, PS: What kind of motor does it have? -- Brad in FL - To be old and wise, you must first be young and stupid |
#2 posted 320 days ago |
You’re going to need a bearing puller to start taking her apart. Check the automotive stores; they’re $10 or less. I think that motor’s worth $100 but you might consider going with a different one. I’ve seen new Baldors on CL for a tad more. This is one of HF’s only good offerings; I hope you end up happy. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#3 posted 320 days ago |
Check the switch. Mine went south, I took it apart and cleaned the contacts after I ordered a new one. Works like a champ, and I now have a spare switch. -- bill@magraphics.us |
#4 posted 320 days ago |
Yea, I second the “check the switch”. Mine melted, I replaced it with a higher amp toggle switch that I got at Home Depot for $3. -- Ken, USAF MSgt, Ret. |
#5 posted 320 days ago |
You mentioned a second dc. For 50 bucks more you can get the whole dc.(149.00) -- Don't rollerskate in a buffalo herd |
#6 posted 320 days ago |
What Bill said….those switches are known to go bad. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#7 posted 320 days ago |
Use your air compressor to blow out any openings where dust might have accumulated. -- John |
#8 posted 320 days ago |
Adam , how old is the DC that won’t work? If it’s less tha 90 days HF will replace the whole unit right at the store. |
#9 posted 319 days ago |
Yeh, my HF DC switch is going out. That was the first thing I thought of when I read the OP’s post. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#10 posted 319 days ago |
Thanks all for the feedback. The unit is 4+ years old. I’ll check the switch with the multimeter tonight. Kickin’ myself for not thinking of that. -- Adam - Red Hook, NY |
#11 posted 319 days ago |
Bearing puller- check with a local auto parts store. Many of them “rent” tools- you put a deposit on the tool, use it and return it and get your deposit back. Our Autozone store does this. -- Regret- the feeling you get just after you do something really stupid. |
| Forum | Topics |
Woodworking Skill Share
8791 |
Woodturning
221 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1530 |
3547 |
15769 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
