| Forum topic by krisrimes | posted 348 days ago | 991 views | 0 times favorited | 14 replies | ![]() |
348 days ago |
I am in the middle of a large order of picnic tables. I need to round over all of the sharp edges as efficiently as possible. I have tried a round over bit in a router and just sanding all of the sharp edges. Neither of these seem to get the job done as quickly as I would like. I am hoping that someone has a technique that I have not thought up, that could be a time saver. Happy 4th |
14 replies so far
#1 posted 348 days ago |
How can you get faster than using a router with a round over bit? Set up your router in a table and route your long edges before assembly. Assemble the tables and route the ends of the table top and seats with the router freehand. Doesn’t get any quicker than that. -- Save lives, ease suffering, reduce morbidity and mortality, stomp out pestilence and disease, postpone the inevitable, and fake compassion. The Paramedics Creed |
#2 posted 348 days ago |
Maybe your using to small of round over bit? -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#3 posted 348 days ago |
Router is my choice when doing roundovers. Fast enough for me unless the radius is too big for a single pass. -- He who dies with the most tools... dies with the emptiest wallet. |
#4 posted 348 days ago |
I’d generally use a laminate trimmer with a small radius roundover If you want to round over all boards, you might try setting |
#5 posted 348 days ago |
Are you using pressure treated timber? – I only ask because of what you’re making and it’s the only wood I’ve found that won’t rout successfully because its so wet. -- Never trust a man in winklepickers |
#6 posted 348 days ago |
My picnic tables all get rounded both top and benches all around. I use 3/8 round over bit in a HF trim router, usually takes 6-8 minutes per table. Quick sanding afterward and tables are much better looking than with square corners. -- I cut it off 3 times and it's still too short! |
#7 posted 348 days ago |
I am using pressure treated lumber and it does not route very well at all. I feel like the odds are that I am using too small of a round over bit. I am planning on trying a bigger bit tomorrow. I guess I was hoping that there was a technique out there that I wasn’t thinking of. |
#8 posted 348 days ago |
1. I built a picnic table today. It sucked! I would never want to make another one. I love woodworking and any excuse to build something and I am all over it! However there is nothing fun about trying to make furniture out of construction lumber, and I hate working with PT. 2. Did something change with PT? I thought it was a big NO to use PT for seating or eating surfaces. I only used PT for the legs and the bench supports. The rest is doug fir which the lovely wife wants to paint. I wanted to use cedar or Ipe, but the wife insists it will be painted no matter what wood I use, so PT and doug fir 2×6’s it was (which the edges are already eased so I didn’t need to do it) Now I have to get that sticky, sappy, chemically sawdust off my circular saw and miter saw blades. There is no way any of this was going through the table saw. What a miserable experience. |
#9 posted 348 days ago |
You could try a technique called bump cutting. You basically go along an edge and keep the base on the surface of the piece and make a series of scallops and come back with a climb cut to clean up the rest of the material. So you would start the cut then skip a section less than the diameter of the cutter cut again and continue to the end. Then go in reverse climb cutting to clean up. It works very well with splintering woods and woods prone to burning. Maybe it will help here. -- Save lives, ease suffering, reduce morbidity and mortality, stomp out pestilence and disease, postpone the inevitable, and fake compassion. The Paramedics Creed |
#10 posted 348 days ago |
Are you using a good quality, sharp bit? Something like this from Infinity would be a good baseline tool (and tool price). Point #2: Rate of feed is one of the 5 Considerations in cutting wood, and you have complete control with a router. If you are interested in speed, I’m wondering if you’re feeding too fast to get a quality cut. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#11 posted 347 days ago |
I’m not sure bit size will make a difference on this. The fibres rip instead of cut because they’re wet. I think on an industrial scale the way they do this is all the shaping first and then send off for pressure treating. I have had the same issue with PT which will neither rout nor sand well. -- Never trust a man in winklepickers |
#12 posted 346 days ago |
Have a look at this Paul Sellers video http://www.youtube.com/watch?v=vcYqPz6LPcA -- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn |
#13 posted 346 days ago |
-- Lucas, "Someday woodworks will be my real job, until then, there's this http://www.melbrownfarmsupply.com" |
#14 posted 346 days ago |
A few swipes with a low angle block plane might get the job done. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
| Forum | Topics |
Woodworking Skill Share
8842 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1597 |
3591 |
15972 |
Hand Tools
2094 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2772 |
LumberJocks.com Site Feedback
1551 |
Coffee Lounge
6130 |
