How to Attach a top to a table base
Forum topic by groland posted 07-04-2012 06:21 PM 7629 views 0 times favorited 7 replies Add to Favorites Watch
View groland's profile
181 posts in 3342 days
07-04-2012 06:21 PM
I am working on some small tables and their tops need to be attached to their bases. I tried making some homemade ones out of wood, and they work fine, but I’d like to use something less bulky. Because everything is solid lumber, I’d like also to use a device that allows for wood expansion.
I found these “Table Top Fasteners” from Rockler, that I think would do. They also sell a “Desk Top Fastener”, but it doesn’t look as though it allows for expansion.
Do any of you know of other hardware for purchase that would do this job? Also, if you fasten your tops to table bases with other techniques, what do you like to do?
7 replies so far
117029 posts in 3508 days
#1 posted 07-04-2012 06:33 PM
Those will do the job,just leave them loose enough so the will move with wood movement.
-- wood crafting & classes
View Sawkerf's profile
1730 posts in 2999 days
#2 posted 07-04-2012 07:25 PM
I use “figure eights” with the screws just a tiny bit short of being tight. I get mine from a local cabinet hardware supply store, but I think that Rockler carries them.
-- Adversity doesn't build reveals it.
View Lifesaver2000's profile
551 posts in 3043 days
#3 posted 07-04-2012 07:26 PM
I have used these fasteners and they work fine, but if you need more than a few, you can save money by buying from McFeely’s (which is what I did). You have to buy the screws separately, but you can get 100 fasteners, 100 screws and with $1 shipping total cost is $13.09. That is about a third of the price per unit as Rocker. If you are doing a lot of tables, you can buy by the 1000 and save even more.
View Bobmedic's profile
379 posts in 2732 days
#4 posted 07-04-2012 09:57 PM
Those are what I use when I make a solid top. Tip: To keep from having to cut a slot down all of the aprons, use a biscuit jointer to cut the slots only where you need them.
View 559dustdesigns's profile
633 posts in 3098 days
#5 posted 07-05-2012 03:16 AM
I second the figure eights. If your table apron is wide enough and you can fit a power drill inside, you could use pocket holes. You may only want to use pocket screws if your top is 3/4” thick or more.
I have seen Norm use hard wood blocks that slide in to a groove in the apron. You could even mill the holes in the blocks for wood movement.
-- Aaron - central California "If you haven't got the time to do it right, when will you find the time to do it over?"
View Brandon's profile
4152 posts in 2882 days
#6 posted 07-05-2012 03:55 AM
+1 on the figure eights (∞). They are easy to use and work great!
-- "hold fast to that which is good"
View Woodknack's profile
11293 posts in 2311 days
#7 posted 07-05-2012 04:17 AM
I have used both hardwood blocks and figure 8’s, the figure 8’s are simpler but both work.
-- Rick M,
