Anyone doing there own wood stabilization??
Forum topic by boneskennedy posted 07-04-2012 04:25 PM 4304 views 0 times favorited 9 replies Add to Favorites Watch
View boneskennedy's profile
boneskennedy
27 posts in 2146 days
07-04-2012 04:25 PM
Are any of you guys doing you’re own wood stabilization? currently im underway stabilizing bowl blanks and it works out very good, i dont ever see any stabilized bowl blanks on the web, have any of you ever turned one??
Jon
9 replies so far
View andysden's profile
andysden
45 posts in 2411 days
#1 posted 07-05-2012 09:11 PM
I have done some 1” pen blanks with urathene just by sealing them in a large jar filling it with blanks then filling with urathene making sure the bla ks stayed submerged in liquid after 24 hours the air quit coming out . The neext time I am going to predrill the blanks as it doesn’t get into the centre . I am hoping to get a vacuum pump to help the proccess What is your location I am in southern ontario Andy
View tyskkvinna's profile
tyskkvinna
1310 posts in 2979 days
#2 posted 07-05-2012 10:36 PM
I stablise all the time. What’s your method?
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
boneskennedy
#3 posted 07-06-2012 01:39 AM
Lis, I use the TK-TR90 heat cure resin and place my blanks in round dry vac chambers and pull vacumedown to 28.5 ” and when under full vacume let resinin chamber, this way there is less resistance for air to be removed from wood being pulled threw resin, currently im stabilizing blanks 18”x 2”x2” i have 6 of these chambers going at all times and the resin and chambers work great.
boneskennedy
#4 posted 07-06-2012 01:44 AM
Andy,you dont need to pre drill the blanks! if you get a vacume pump make sure its a two stage so you can get the most vacume possable im pulling 28.5” and can stabilize 3”x3”x18” blanks with no problem useing the TK-Tr 90 resin if you need a chamber let me know what size wood blanks you are doing and how many at a time and i can possabily help you out with chamber! better yet give me a call 320-212-1504
Jon
boneskennedy
#5 posted 07-06-2012 02:07 AM
If any of you need any information on the ZK-TR90 resin you will need to Pm me you’re email and i will forward all the info to you
Jon
View treaterryan's profile
treaterryan
109 posts in 2280 days
#6 posted 07-11-2012 03:00 AM
Have you looked into pentacryl? I know nothing about turning, but I have heard of some pieces being treated with pentacryl before for an artist.
-- Ryan - Bethel Park, PA
View dwilli19's profile
dwilli19
1 post in 2128 days
#7 posted 07-22-2012 01:48 AM
Hey Bones, can you PM me info on where to get the ZK-TR90 resin? I starting to turn duck calls and would like to be able to stabilize my own blanks. Thanks.
Dave
boneskennedy
#8 posted 07-22-2012 09:11 PM
Dave, Not a problem send me a email to bones@plainstatesenergy.com and will be gladto help you out! I also turn many calls a year! been making calls for about 10 years, so if you need any help with the call making give me a call.
Bones
View Dezmond's profile
Dezmond
3 posts in 1740 days
#9 posted 08-13-2013 04:32 PM
Hey Jon.. I would love to get some more info from you on your stabilizing process.. Shoot me an email at dezi@execulink.com when you can..
Thanks,
Dezi
