Best grease for lubing the TS?
Forum topic by Cato posted 07-04-2012 01:35 PM 2606 views 0 times favorited 16 replies Add to Favorites Watch
View Cato's profile
Cato
701 posts in 3551 days
07-04-2012 01:35 PM
What grease do you use when its time to re-grease your table saw gears?
Also do you use a cleaner on the gears to get the old grease off??
16 replies so far
View lieutenantdan's profile
lieutenantdan
176 posts in 2545 days
#1 posted 07-04-2012 02:02 PM
White lithium grease. Home Depot. White tube looks like giant tube of toothpaste. Made by Lucas, I think. If the old grease has hardened, use a Dremel with wire brush (wheel) to remove old grease.
-- "Of all the things I have lost in life, I miss my mind the most."
View Lee Barker's profile
Lee Barker
2170 posts in 3089 days
#2 posted 07-04-2012 02:35 PM
I would think the grease would attract chips and dust whose presence would negate the value of the grease.
Kindly,
View OnlyJustME's profile
OnlyJustME
1562 posts in 2616 days
#3 posted 07-04-2012 02:48 PM
i used T-9
http://www.amazon.com/Boeshield-Corrosion-Protection-Waterproof-Lubrication/dp/B001447PEK
-- In the end, when your life flashes before your eyes, will you like what you see?
View Bernie's profile
Bernie
422 posts in 3076 days
#4 posted 07-04-2012 04:07 PM
I think like Lee – grease would make it worse.
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
View Clint Searl's profile
Clint Searl
1533 posts in 2600 days
#5 posted 07-04-2012 04:14 PM
I use a graphite lubricant that dries to a non-greasy film.
View Dallas's profile
Dallas
3599 posts in 2726 days
#6 posted 07-04-2012 04:19 PM
When you use graphite you might run into problems getting it to go uphill. I use an old mustard squeeze bottle and mix a bottle of graphite with about a half a bottle of rubbing alcohol.
The graphite squirts where you want it and sticks until the alcohol dries out, leaving no residue.
View DKV's profile
DKV
3940 posts in 2743 days
#7 posted 07-04-2012 04:26 PM
I have used grease and it managed to collect a lot of sawdust. Made cranking very hard. I now use wd40 and have no problems. I like the graphite approach. Also, I think we should clean the underpinnings of our saws more often then we do.
-- This is a Troll Free zone.
View longgone's profile
longgone
5688 posts in 3547 days
#8 posted 07-04-2012 04:42 PM
I would never use grease…it is a dust magnet and is asking for problems. I have used the Boeshield T-9 for years with no problem whatsoever.
View Sawkerf's profile
Sawkerf
1730 posts in 3307 days
#9 posted 07-04-2012 06:02 PM
I’ve used white grease but didn’t like the way it collected dust and shavings. These days, I use a spray on dry lube. Evertyhing travels smoothly and there’s no “gunk”.
View Terry Ferguson's profile
Terry Ferguson
203 posts in 2906 days
#10 posted 07-04-2012 06:20 PM
I have successfully used both these products:
1. Bostik Top Cote dry lube in a spray can – dries slightly chalky – works on all machine tops
2. Tri-Flow lubricant with Teflon in a squeeze bottle – dries clear and doesn’t attract dust
-- Terry Ferguson, Bend Oregon
View Cato's profile
Cato
#11 posted 07-04-2012 09:55 PM
Thanks guys for your responses. Obiviously grease is out.
Sounds like a dry lube would indeed work the best.
I agree that grease would attract the sawdust and accumulate in the gears.
Table saws always come with grease painted on the moving parts, but doesn’t really make sense given the nature of it producing fine sawdust.
Think on my next maintenance I will try to wipe off the grease on my saw and put a dry lube on.
View NiteWalker's profile
NiteWalker
2738 posts in 2816 days
#12 posted 07-04-2012 11:04 PM
I use paste wax. Use sparingly and it won’t attract dust. Always have on hand; no need for another chemical/item to lose in the shop.
A brass bristle brush gets the gunk off.
View Loren's profile
10477 posts in 3887 days
#13 posted 07-04-2012 11:40 PM
I use paste wax too. It’s cheap and not a hassle to keep on hand
like sprays. Graphite lube wears off incredibly fast. WD-40 is
kerosene in a spray can and it will dissolve grease in sealed bearings
so be careful with where you apply it.
View Mainiac Matt 's profile
Mainiac Matt
8615 posts in 2567 days
#14 posted 07-05-2012 02:45 AM
Table saws ( like most machines) come with preservative grease slathered on the unpainted surfaces to prevent rust during that long boat ride across the Pacific. This should be cleaned off as part of the set up procedure.
If I’m not mistaken, WD40 is actually formulated with fish oil…. And was the product of the 40th test formulation for a new water displacing oil.
-- I yam what I yam and that's all what I yam
View whitewulf's profile
whitewulf
456 posts in 3176 days
#15 posted 07-05-2012 02:49 AM
Renderd Bear Fat…...
-- "ButI'mMuchBetterNow"
