| Forum topic by mzimmers | posted 325 days ago | 724 views | 1 time favorited | 16 replies | ![]() |
325 days ago |
Topic tags/keywords: router template bushing jig Hi, all - I have a rather unusual project that is going to be tricky to describe. Imagine that you have a smallish block of wood (say, 6” by 12” by 1”). You wish to cut a relief into one face of the wood that is 1/2” deep and 4” by 10”, leaving a 1” border on all four sides. I’ve heard of using templates, jigs and bushings for this, but I’m having trouble putting the whole idea together. First of all, I don’t understand the process of making a template. It seems like you need a template to make a template! If someone could help me over this hump, that would be great. I get that if I use a bushing, I need to oversize the template by 2X the difference between the radius of the cutter, and the diameter of the bushing. I think I have that covered. So, assuming that I’ve already got the proper template, do I center it over the workpiece and clamp it down? Do people typically make templates large enough to leave room for clamping? And, what is done to secure the work underneath the template? Would I fasten something to the table to prevent movement of the work, or or do I build an “under-template” that would hold the work in place? Thanks for any clarification; I hope I made sense in this post. -- M. Zimmers, central CA |
16 replies so far
#1 posted 325 days ago |
You can use double-sided tape to tape the template to the workpiece. Or make a framework to hold the workpice and template. Or make the template larger and use clamps to hold the template and workpiece in place. For a single item the tape would probably be the easiest… Good Luck Be Careful! Herb -- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090 |
#2 posted 325 days ago |
Not sure what your calling a relief do you mean a rabbit or a groove leaving some wood on the top and bottom with a groove in the center of the edge ? -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#3 posted 325 days ago |
Jim - Yeah, I didn’t think I was using the right word. Picture a board 1/2” by 12” by 6”. Now imagine some 1/2” by 1” strips, 2 of which would be 12” long, and 2 of which would be 4” long. Lay the strips along the perimeter of one face of the board, glue/screw in place, and that’s the shape of what I want. Except, made of a single piece of wood. Rounding on the inside corners is OK. -- M. Zimmers, central CA |
#4 posted 325 days ago |
Ok if I understand right all you have to do is make a cut on all edges 1” deep on the table saw and then lower the blade so it’s only sticking up a high enough to just leave the 1” around the top and then cut the board laying flat cutting of all the edges . -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#5 posted 325 days ago |
Heh…no, I’m doing a really lousy job of describing it. I don’t want cuts on the edges; I wish to keep the edges intact. I want a 1/2” “cutout” inside of the edges. Picture a shallow, flat-bottomed, rectangular bowl. Maybe that will help. -- M. Zimmers, central CA |
#6 posted 325 days ago |
you want to dish out a 1/2” on the flat side of the board ? -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#7 posted 325 days ago |
Yes, leaving a raised edge on all four sides. (My dimensions may change a bit; I was just trying to keep the example simple.) This is going to hold a rectangular glass ashtray. -- M. Zimmers, central CA |
#8 posted 325 days ago |
I hate to come full circle but what Herb C suggested was pretty close. It’s very similar to making routered bowls . http://www.woodsmithshop.com/download/302/routedbowls.pdf -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#9 posted 325 days ago |
Maybe draw a picture? Top, side, and end view maybe? |
#10 posted 325 days ago |
Hey, Jim - I think you have the idea now. I like that article you linked, though I’m not sure I need quite the level of elaboration called for there. Instead of cutting my template, can I use some 1” stock and screw it to a large base? That would seem easier, and result in cleaner edges to follow. Thanks! -- M. Zimmers, central CA |
#11 posted 325 days ago |
Good luck I hope comes out ok. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#12 posted 325 days ago |
I would just take a piece of stock substantially bigger, screw some 1xs alongside your box and screw some more to the top reaching in to the point that you want. Then go to work. Basically a box to how your wood, then a frame over it to match the border you want left. -- As long as our customers are happy, we have done a good job. Even if we are our own customer. |
#13 posted 325 days ago |
I get what you’re saying. I would first clearly mark lines 1” from the edge for visual reference, then use a guide on my router to get it 1” in from the edge. When cutting the initial “groove” just be careful not to go past the lines. Do all four edges, then remove the router guide and route out the inner part, starting from the center and working my way out. I would start from the center so the bottom plate of my router always has something to rest on, to keep from plunging too deep. It would require some patience, but it beats making a jig or a template just for a single item. What you say about needing a template to make a template made me chuckle a little, because I remember thinking the same thing some time ago. Making a template is very time consuming and requires a lot of patience, and is usually made using different tools, such as a band saw, edge sander, etc… But once the template is done, it’s much faster to crank out lots of identical pieces using the router. I have never made a template for a single item, since it’s easier to just go ahead and make the item. |
#14 posted 325 days ago |
i’ve done something similar to what you are describing. here’s how i did it: -use a table saw to cut some L shaped pieces, make one leg of the L the thickness that you want the “bowl” sides to to be. make sure you cut enough L pieces to wrap the perimeter of your project. |
#15 posted 325 days ago |
Remedyman: I would do that, except that the stock I’m contemplating is going to be pretty pricey (I’m thinking of African blackwood). Samadams: I’ll consider that, though I don’t mind making a pattern/jig of some kind. It’ll be a good learning experience for me. Plus, I like to work in such a way that relies least on hand/eye coordination. bent: interesting approach. Have you ever tried clamping your framing pieces instead of gluing them? Thanks for all the ideas, everyone. -- M. Zimmers, central CA |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3555 |
15813 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
