who wears gloves in the woodshop
Forum topic by ssnvet posted 320 days ago 1378 views 0 times favorited 50 replies Add to Favorites Watch
View ssnvet's profile
ssnvet
1528 posts in 495 days
320 days ago
Topic tags/keywords: gloves workshop safety
I always wear the knit gloves dipped in rubber when I’m swinging a chain saw and splitting wood, or doing landscaping outside.
But The conventional wisdom I’ve always heard is not to wear loose fitting clothes, long sleeves or gloves when using machinery…. and that’s what we preach at work… so I don’t wear gloves in my shop.
However, this past week I manage to do two stupid things in the shop, that has me rethinking this. First, I stuck a very sharp chisel into the pad of my left index finger while cleaning up a glue joint, and then I slid my hand down an 8/4 maple board while handling it, and jammed a large splinter deep into my palm.
During last summers project (a tree house for my kids) I indulged myself with a $10 pair of those tight fitting mechanics gloves, with cut to fit leather palms and fingers, and stretchy nylon backs. I really like that pair of gloves (though I wore holes in the finger tips in just a few weeks).
So I’d like to poll the crowd and see who is wearing gloves in the work shop???
If you wear gloves, what kind???
And if not, what’s your reasoning???
-- Matt, Pine is fine, but Oak's no joke!
50 replies so far
View woodworm's profile
woodworm
14104 posts in 1757 days
#1 posted 320 days ago
No.
I touch my lumber, my machines with love not gloves!
-- masrol, kuala lumpur, MY.
View HalDougherty's profile
HalDougherty
1820 posts in 1403 days
#2 posted 320 days ago
I’ve worked in too many factories to ever wear a glove, long sleeves, watch, or ring around machinery. I’ve seen almost every type of accident that could have been prevented if the operator had not been wearing something that could pull a hand into moving equipment. Or in one case a long haired lady who did not have on a hairnet while running a punch press. She didn’t get pulled into the press, but it took a long time for the patch of hair and skin that got pulled off to grow back. A welder who worked for me was welding a big steel plate to reinforce a 150 ton press let his stainless steel ring touch both the grounded plate and machine at the same time… In an instant his ring was stuck tight to both pieces. We didn’t have to go to the effort of cutting a stainless steel ring off his finger because it burned right off and cauterized the wound. Yep, I fired him for wearing a ring while welding. He’d been given a list of safety rules to follow one of which specifically prohibited steel rings… He’d also been sent home once for wearing a ring while welding. Nope, I’d rather have a few cuts and scratches I wouldn’t get wearing gloves, but they will heal,and something that gets cut off might not get reattached or grow back.
-- Hal, Tennessee http://www.first285.com
View waho6o9's profile
waho6o9
2884 posts in 743 days
#3 posted 320 days ago
I never wear gloves in the wood shop.
Reason is for safety, and I don’t find them comfortable when milling lumber because
I concentrate on that spinning blade and router bit etc.
View Don W's profile
Don W
9934 posts in 734 days
#4 posted 320 days ago
I typically don’t were gloves using machinery like the table saw, but I have two types I do use. I have a pair of leather gloves I wear when using the wire wheel or polishing. They have saved my hide (literally) many times. I also wear rubber coated when apply finishes and sometimes when sharpening. I find these task are hard to clean up after and there is no risk of injury because of the gloves.
View johnstoneb's profile
johnstoneb
263 posts in 339 days
#5 posted 320 days ago
I depends what I am doing. Around the drill press and most other power tools I don’t wear gloves. If I am ripping long board on the table saw, I may wear one glove on my left hand as it slides on the edge of the board. With hand tools I may wear them to protect myself from using chisels etc. wrong.
I don’t wear rings! I worked as a mechanic for a John Deere dealer years ago. One of the mechanics was working on a 24V system when he got his wedding ring between a battery and ground. The 24V’s burnt the hell out of his finger ruined the ring. When he got home he caught hell for ruining the ring and no sympathy for the burnt finger. He didn’t wear a ring at work anymore.
-- Bruce
View renners's profile
renners
1881 posts in 1135 days
#6 posted 320 days ago
Bad idea. Snag risk.
I only wear gloves if I’m handling a large quantity of rough sawn timber.
Won’t go anywhere near a machine with gloves on.
-- Do or do not, there is no try
View NiteWalker's profile
NiteWalker
1467 posts in 743 days
#7 posted 320 days ago
No gloves in the shop, only a leather pair when using the angle grinder.
Dem sparks is hot!
View Bill White's profile
Bill White
2601 posts in 2127 days
#8 posted 320 days ago
Nitrile gloves when finishing/stripping (furniture,etc.), kevlar woven gloves while sharpening knives, leather with lawn implements.
Bill
-- bill@magraphics.us
View lumberjoe's profile
lumberjoe
2396 posts in 415 days
#9 posted 320 days ago
I wear rubber gloves when applying finish or using certain glues that irritate my skin, however NEVER when using anything with a blade – powered or un-powered.
I do wear gloves with certain power equipment, mostly lawn equipment. Chainsaws for obvious reasons, and the lawn mower/string trimmer to ease the vibration a bit, and I do wear mechanics gloves when working on my cars. Not to keep my hands clean, but I barely have any meat on my knuckles anymore from tearing them up swinging wrenches into jagged metal.
Again, I would never even consider putting them on in the wood shop.
-- http://www.etsy.com/shop/KandJWoodCrafts
View Oldelm's profile
Oldelm
71 posts in 341 days
#10 posted 320 days ago
I never wear gloves, jewelery, loose clothes around machinery. i have personnaly seen way too many accidents and even seen accidents that were made worse by one of the things above. I do use gloves when handling lumber and I have taken to wearing a cavring glove on my hand holding the tool more because of the fact that I am not as steady as I used to be and was getting more nicks from the sharp tools. Even that carving glove takes some of the feel of the tool away. It surprising how many of your senses you use in woodworking. I don’t even listen to a radio in the shop because I can’t hear what the tool is doing, hand or power..
-- Jim, Missouri
View ChuckV's profile
ChuckV
1747 posts in 1693 days
#11 posted 320 days ago
I use nitrile gloves when applying finish. I do have a pair of protective gloves in my shop. I use them when I change the blade on my bandsaw. I remove them before I even start spinning the blade by hand. I also use them sometimes when handling rough-swan lumber.
-- "Too much hurry ruins the body. I'll sit easy … fan the spark" - I. Anderson
lumberjoe
#12 posted 320 days ago
Jim, that is so true. I should wear hearing protection more than I do, but the only time I wear it is with a planer and when sanding a lot (the sander and the shop vac are a noisy combo). My routers are VERY loud as well, but I find I rely on the sound as much as I do as the feel of the tool. I can tell exactly what the router is doing to the wood by listening to it, and a lot of times I will adjust feed rate or depth of cut based on that sound.
View Mosquito's profile
Mosquito
2755 posts in 459 days
#13 posted 320 days ago
I also wear gloves finishing, and sometimes when cutting joinery by hand. I’ll wear gloves when handling larger amounts of rough stock as well. I used to wear gloves while working with my router table, but not anymore. Sometimes I’ll wear them sharpening, for the reason Don stated, it’s messy.
An expansion: Often when I wear gloves when cutting joinery by hand, it will be just one glove. For example when repeatedly striking chisels and guiding them by hand, I’ll wear a glove on the hand guiding the chisel. I’ve slipped once and put a nasty slice in my finger, and the chisel sides sliding over my finger gave me some annoying cuts. Started wearing a glove for that reason, but leave the other one ungloved so I can keep a better feel when doing other work with the chisel, or a saw, etc
-- Mos - Twin Cities, MN -- Stanley #45 Evangelist - www.youtube.com/MosquitoMods
ssnvet
#14 posted 320 days ago
what about with sanding stations???
I’ve taken some sizeable pieces of flesh off with a belt sander … and they can’t really grab you and pull you like a blade can.
Mosquito
#15 posted 320 days ago
I guess I wear my gloves when I use the ROS, I try not to use it too often, though. I don’t have things like table saw, band saw, drill press, spindle sander, belt sander…
showing 1 through 15 of 50 replies
