Cheap stanley block plane
« back to Hand Tools forum
Forum topic by 12strings posted 320 days ago 647 views 0 times favorited 6 replies Add to Favorites Watch
View 12strings's profile
12strings
183 posts in 550 days
320 days ago
Does anybody else have this $20 stanley block plane (from lowes)?
http://www.lowes.com/pd_97159-355-97159_0__?productId=1210163&Ntt=block+plane&pl=1&currentURL=&facetInfo=
I can’t figure out how to make it hold the blade tightly and still be adjustable? Any tips for making it work better, or is it a lost cause?
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
View Grandpa's profile
Grandpa
2380 posts in 841 days
#1 posted 320 days ago
I have a Stanley that looks something like that one. I bought mine in a garage sale for $1 and I got a good deal on mine. I am not sure it is the same as yours though. I don’t have any problems with mine.
View ksSlim's profile
ksSlim
800 posts in 1055 days
#2 posted 320 days ago
I have several “vintage” planes but have looked at the “new” 220 at Lowes.
The ‘durable epoxy coating’ could be giving you problems. Where the iron cap or chip breaker meets the blade, remove the “durable epoxy” coating. Adjust tension on the cap screw, then when you turn the lock lever, you should have the proper tension on the blade and still adjust cut depth.
-- Sawdust and shavings are therapeutic
4870 posts in 1813 days
#3 posted 320 days ago
You have to fiddle with the screw to find the sweet spot where
the lever holds the iron tight but not too tight…. too tight and
the iron bows up and chatters in the cut. After you’ve found
the spot (less than 1/8th of a turn range sometimes) you
can put some loctite on the screw.
View ShipWreck's profile
ShipWreck
534 posts in 1918 days
#4 posted 319 days ago
I have this plane. It is laying under the back seat of my truck as I type this. I bought it to shave a few sticking doors at some properties.. I have the same problem with adjustments.
KsSlim: Good point…....I’ll try removing the epoxy and see what happens.
View dhazelton's profile
dhazelton
828 posts in 462 days
#5 posted 319 days ago
What Loren said. Mine is from the 90’s and works just fine, makes whisper thin shavings and does end grain ok. I don’t know if the quality of steel or machining is the same today though.
View chrisstef's profile
chrisstef
5204 posts in 1172 days
#6 posted 319 days ago
Ksslim’s got it nailed. Ive got the english version of this plane and the underside of the cap has that black paint / epoxy on it. Sand it off and you’ll get a nice tight fit that will hold much better.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
