Question: How do you properly measure for dado's on a router table?
Forum topic by Milo posted 351 days ago 1191 views 0 times favorited 20 replies Add to Favorites Watch
View Milo's profile
Milo
813 posts in 1516 days
351 days ago
OK, another question this evening. How do you guys measure the distance from the router bit to the fence to properly cut your dados in the right distance from the edge of your boards?
Now, I’m sure the guys with the fancy router tables with the snazzy Jessem router table fence just say something like “dial it in”. Well, you guys stink. ;) And yeah, I’m hideously jealous.
BUT for those of us with the shop made fence that we have to place by hand and clamp in place, how do you guys do it and get reliable cuts?
Thank you for your answers,
Milo
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
20 replies so far
View gizmodyne's profile
gizmodyne
1762 posts in 2287 days
#1 posted 351 days ago
If you want the dado an inch from the edge, Stick a piece of one inch material in between the fence and bit.
Or you can mark the dado on the edge of your board. Line it up with the bit on the right side of the fence. Set that side of the fence with a clamp.Take the set up board to the left side of the bit. And swivel the fence to meet your mark.
View bruc101's profile
bruc101
526 posts in 1739 days
#2 posted 351 days ago
I agree with John and or you can make yourself a “story stick”.
-- Bruce http://plans.testsitem3.info http://www.sawmillgirls.com
View Grandpa's profile
Grandpa
2399 posts in 873 days
#3 posted 351 days ago
Then always run a test on a scrap befor putting the good stuff to the bit.
View Joe Lyddon's profile
Joe Lyddon
6475 posts in 2249 days
#4 posted 351 days ago
Here is a COOL router dado jig.
This little jig will do a great job of cutting dados in sides for shelves… etc.
Most dados are not easily cut using a router table fence… rabbets are another story, going the Long direction… where you line it up as if you were using a table saw… you have a fence… you have a bit…
Are these for your shelves? Dadoing sides for the shelves?
Sounds like you need a story stick which was made from the Plans…
To be sure each side lines up with the other, it may work out to put the sides together, side by side, and cut the dados for both sides at the same time (setup).
Are you talking about a possible Stopped dado so the groove is not shown from the front?
I’m shooting in the dark… I’m not sure what you want to do…
Hope this helps…
What are you really talking about?
View Milo's profile
Milo
#5 posted 351 days ago
I was just thinking about stopped dados for mortises. I’m playing with several different ideas right now and was watching am old (1989!) New Yankee Workshop where he was using a simple router table.
View lumberjoe's profile
lumberjoe
2424 posts in 445 days
#6 posted 351 days ago
Some people may cringe at my method but I have really good luck with it and it serves three purposes – especially for stopped dados.
1. First I draw where I want the dado on the piece.
2. I then grab a forstner bit that is however large I want the dado to be.
3.I chuck it up and drill a hole at the start and end of the dado.
4.I then place the piece on the router table with the hole over the bit.
5.Square the work piece to the table using combo square or your favorite method.
6. Set your fence. Pull your piece off and make sure the fence is square.
The added bonuses:
1. You can get your bit depth really close if you were careful drilling. Only very minor adjustments will be needed
2. You will know EXACTLY when to stop the cut because you already have a hole drilled. I still make pencil lines and match them up, but I can tell by the sound of the bit when I am done.
-- http://www.etsy.com/shop/KandJWoodCrafts
View chrisstef's profile (online now)
chrisstef
5577 posts in 1203 days
#7 posted 351 days ago
I like to use drill bits to measure the distance from the fence to the bit, just lay the shank end of it against the fence and slide it over til it just hits the router bit.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View Gene Howe's profile
Gene Howe
3217 posts in 1626 days
#8 posted 351 days ago
I like Joe’s and Chris’ methods. I use set up bars or the drill bit method, also.
I’ll try Joe’s next time.
I’m all for direct measurement, ala set up bars, drill bits, story sticks, etc. The less often I can get by with using a ruler or tape, the happier I am.
lumberjoe
#9 posted 351 days ago
I have a hard time measuring to the exact edge of a round fluted bit. That is why I do the hole drilling method. It has worked out great for me so far. Also starting and stopping the cut in pre-drilled holes eliminated any tear out and burning I was getting.
View renners's profile
renners
1952 posts in 1166 days
#10 posted 351 days ago
I use one of these handy little devices.
Also perfect for checking bit height
-- Never trust a man in winklepickers
View Milo's profile
Milo
#11 posted 350 days ago
Renners, that just suck. How dare you throw something so practical into the mix…
btw, where’dya get it? ;)
Seriously, that is cool. “Trend” measuring tool? Off to google… Ah, Rockler has it. Christmas list!
Joe, I like what you suggested. But here’s another stupid question. Since the router bit is a single point in the center of the table, does the fence really need to be “Square”? As long as it’s straight, shouldn’t your wood pass in a straight line past the center router bit? Right?
More mud for the looking glass…
Joe Lyddon
#12 posted 350 days ago
Milo,
I didn’t want to butt in and start something… LOL
You are 100% correct!
The main thing about a Router Table Fence is that it must be Straight!
... if it’s straight (180) ... you do NOT have to worry about your Fence being square…
I’ll ask you… How would you measure to find out if it WAS square?
You can’t… unless you do it with a Straight Edge to be sure the fence is a pure 180
! LOL
If you have a straight edge on a Workpiece and you adjust the fence to straight-bit distance to 1/2”, you will get a groove 1/2” from the edge of the workpiece all along the board. It makes NO DIFFERENCE where the fence is on the table… it can be anywhere… You’re merely adjusting the distance from the fence to the bit… That’s it.
I hope that answers your question… so you understand it… LOL
Thank you.
View Milo's profile
Milo
#13 posted 350 days ago
Joe, you NEVER butt in! ;)
lumberjoe
#14 posted 350 days ago
Joe is right. I just never have enough confidence that my work piece is straight, so I never set my fence based on that. I use it for spacing only
View Dusty56's profile
Dusty56
10727 posts in 1885 days
#15 posted 350 days ago
lumberjoe , that is a unique method that you use , but I ‘m going to give it a shot next time I’m in need.
Thank you : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
