How to attach to a wall
Forum topic by Derakon posted 12-08-2012 03:21 AM 5704 views 0 times favorited 8 replies Add to Favorites Watch
View Derakon's profile
Derakon
89 posts in 2401 days
12-08-2012 03:21 AM
I’d like to make some shelves that attach directly to studs in the wall, but I’d like to not have any screws or nails showing in the piece, if possible. That would seem to require some kind of “hanging” mechanism (where there’s a hook mounted on the wall, and the piece hangs from the hook), but I don’t know how to go about designing something along those lines, especially since I’d want the piece to be flush with the wall and, ideally, fairly immobile. Not because I expect the shelves to take a lot of load, just because it’d seem sloppy otherwise. Does anyone have any advice?
The only idea I’ve had so far would be to route out a slot in the edge of a board, then glue in a thin strip over most of the slot, which would create an area that could be hooked into. I still don’t know how the hook itself would work though.
8 replies so far
View AandCstyle's profile
AandCstyle
3184 posts in 2490 days
#1 posted 07-02-2012 01:02 AM
Google “french cleat”, then ask any questions you still have. HTH
-- Art
View RRBOU's profile
RRBOU
176 posts in 2525 days
#2 posted 07-02-2012 01:43 AM
I just completed some floating shelf’s that were 24” long and 6” wide. I used sliding dove tails. This worked very well and they are very sturdy. I put the pins on the outer part of the shelf and then counter sunk the screw in the grove of the 1-1/2” inside portion of the shelf.
-- If guns cause crime all of mine are defective Randy
Derakon
#3 posted 07-02-2012 02:17 AM
AandCstyle: thanks! Sometimes the problem is just not knowing the terminology…carpentry’s had a long time to come up with different ways of naming things. :)
RRBOU: that also sounds like it’d work well. I haven’t done any dovetail work yet, though I do have the appropriate bit for my router.
View woodworm's profile
woodworm
14470 posts in 3824 days
#4 posted 07-02-2012 04:14 AM
Derakon, The french cleat looks like this:
-- masrol, kuala lumpur, MY.
View waho6o9's profile
waho6o9
8539 posts in 2810 days
#5 posted 07-02-2012 04:19 AM
+1 for the French cleat.
Nice diagram Woodworm.
woodworm
#6 posted 07-02-2012 05:05 AM
Waho609, I should not get the credit for the diagram – I copied it from the web coz I could not paste the link.
View woody123's profile
woody123
53 posts in 3540 days
#7 posted 07-02-2012 08:32 PM
+2 for the French cleat. The screws that hold the cleat to the wall can be plugged with decorative wood plugs.
I have a couple of shelves and cabinets around my house hung this way. They are very strong.
Just my .02
View GrandpaLen's profile
GrandpaLen
1651 posts in 2506 days
#8 posted 07-02-2012 10:14 PM
Welcome to LumberJocks , a world of advise, opinions, and experiences, all shared without judgement.
If it’s not a heavy shelving unit nor a heavy load you can use a ‘key hole’ router bit and this will hide your hanging solutions.
I have used this method on several 3 and 4 shelf units for Knick Knacks and DVD/CD storage, wieghing up to 25 – 30 lbs.
You will want to make the slot with the plunge hole at the bottum, (think tear drop shape) in the style frame. You can also make horizontal slots shaped like a dog bone, in the rail frame. – Len
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
