Re-Purposing Pallets
Forum topic by lew posted 322 days ago 1464 views 0 times favorited 8 replies Add to Favorites Watch
View lew's profile
lew
8972 posts in 1921 days
322 days ago
Topic tags/keywords: pallets tip resource
Just received this in an email from Andy's EZwoodshop. Just reposting it here for your consideration.
Ever build something from a wood pallet? I remember all the buzz about pallet furniture from a couple years ago, but apparently it’s still going strong today, especially with some of the newer photo sharing sites like Pinterest. I’ve seen everything from pallet tables, pallet chairs, pallet beds, and even pallet kids’ toys. Truth is I have very mixed feelings about the fad. As interesting as some of the projects are, I doubt I will ever build furniture from a wood pallet. Here’s why.
So What’s the Problem with Pallets?
Everything from soda pop to cyanide gets shipped on pallets. And because pallets are repaired and resold (many times over), it’s nearly impossible to know what a recycled pallet has been used for during its lifetime. More often than not, a wood pallet does have bacteria and other contaminants lurking under the surface. For those who aren’t up to date on the subject, here are a few things to consider before bringing pallet furniture into your home.
Bacteria in Wood Pallets
Do you recall a couple years ago when wood pallets made national news? Twenty people from Michigan, Ohio, and New York ended up in the hospital after eating lettuce infected with E.coli. Where did the E.coli come from? You guessed it—wood shipping pallets. Of course, this discovery opened a fresh can of worms for the FDA, who had always let the shipping pallet industry operate freely without regulation. After the big lettuce recall (in 23 different states), the FDA quickly put forth a set of food-safety guidelines for shippers, but no laws to actually enforce them.
Fungicides in Wood Pallets
A lot of wood pallets are treated with pesticides and fungicides before they leave the assembly line. That’s because insects and mold love to hide in the grain of the wood, which is a big problem for companies that ship things around the world (ever hear of Dutch Elm disease?). These chemicals can’t be removed (or easily covered for that matter), and can continue to release toxins in the air for years to come. As a result, treated pallets are a bad choice for any kind of project you might want to keep in the house.
Still Want to Do It?
I’m kind of a germophobe to begin with, so there’s no convincing me that building pallet furniture is a good idea. However, I realize a lot of people love the idea and are determined to build something with a pallet no matter what. With that in mind, here are some practical tips for getting started—and how to avoid some of the more common pitfalls of the craft.
Recycled Pallets – What to Avoid
Sometimes you can spot which recycled pallets to avoid simply by paying attention to how the wood looks, feels, and smells.
> Smells Bad. This is a dead giveaway that bacteria is growing somewhere on the pallet. Leave it alone and look elsewhere.
> Looks Oily. This is a good indicator that the pallet was treated with some type of fungicide (to prevent mold and wood rot). Keep looking.
> Spots and Stains. This can mean only one thing: SPILLS. There’s no telling what might have leaked, so don’t even touch it.
Recognizing a Treated Pallet
Treated and non-treated pallets can sometimes look the same. Here are a few clues to help you recognize the difference. First see if the pallet is marked with the following letters:
MB – (Methyl Bromide). MB is a toxic pesticide applied to wood pallets to kill insects. Although pallet manufacturers are phasing out the process, you will still see this mark on older, recycled pallets.
HT – (Heat Treated). HT is also a process that also kills insects. The method is considered safer than using MB, but can still include the use of other hazardous chemicals.
Does it Feel Extra Heavy?
Sometimes the weight of a pallet can be an indicator that it’s been treated with fungicides, especially if the wood also has an odd color.
Cleaning Recycled Pallets
If you’re confident you’ve found a wood pallet that’s free of bacteria (as free as it can be anyway) and doesn’t appear to be treated with fungicides, it’s still a good idea to scrub the pallet down with bleach and soapy water. Keep in mind that bacteria might still be embedded in the grain even after a thorough cleaning. That means wood from a pallet should never come in contact with food, children’s toys, or children’s furniture, regardless of how well you clean the surface.
Working with Recycled Pallets
Pallets are usually riddled with nails, splinters, and other sharp edges that make working with the material especially hazardous. Plus, the dust created from cutting or sanding a pallet treated with fungicides and/or pesticides can be extremely toxic. Always use the following safety precautions when working with recycled pallets:
> Wear gloves to avoid splinters, cuts and punctures.
> Wear safety glasses to keep stuff out of your eyes.
> Wear a dust mask to keep fungicides out of your lungs.
Be safe in the shop!
Andy
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
8 replies so far
View Marpintero's profile
Marpintero
112 posts in 1453 days
#1 posted 321 days ago
Well said Lew. It is very important to know that recycling, like everything in life, must take into account certain issues. I think you stated very well and will be of great help to many.
Thank you very much.
Martin
Bien dicho Lew. Es muy importante saber que el reciclaje, como todo en la vida, debe realizarse teniendo en cuenta ciertas cuestiones. Creo que las has expuesto muy bien y serán de gran ayuda para muchos.
Muchas gracias.
Martín
-- Marpintero, Argentina
View ShipWreck's profile
ShipWreck
534 posts in 1919 days
#2 posted 321 days ago
I recently met a new freind who has been using pallet wood for years and never had a problem. He is fairly poor and uses what he can get his hands on. He stops by the car wash on the way home and washes them down. I imagine a good pressure washing would eliminate any problems with contamination.
Sounds to me that Andy might be a bit phobic.
View mafe's profile
mafe
8055 posts in 1255 days
#3 posted 321 days ago
Interesting article.
Thanks.
Best thoughts,
Mads
-- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking.
View ssnvet's profile
ssnvet
1527 posts in 494 days
#4 posted 321 days ago
None of the heat treat processes I’ve seen involve any chemicals directly. They simply “cook” the pallets. How the heat is generated does vary, with some processes exposing the pallets directly to the exhaust from the burning of natural gas (or propane)
-- Matt, Pine is fine, but Oak's no joke!
Beginningwoodworker
13225 posts in 1839 days
#5 posted 321 days ago
Nice article, Lew.
-- CJIII Future cabinetmaker
View Roger's profile
Roger
9191 posts in 970 days
#6 posted 320 days ago
It’s good that u posted this Lew. yes, I get the same email. It makes a lotta sense. I actually used to keep (still have about 8 or 10) a small stack of em just for burning. I believe this is one o them things that folks just gotta use a thing called common sense. I know there has been some nice projects done from pallets outta these pages. I was ahead of this little article because I said about a month ago, this is the last o the pallet campfires. Use yer noggins folks. That’s the botom line
View redryder's profile
redryder
1587 posts in 1268 days
#7 posted 320 days ago
I have always felt pallets were too much of a hassle to tear down, de-nail etc. Now you have given me more reasons to not use them. Recycling seems to make some people feel all warm and fuzzy. It may also make them feel sick…................
-- mike...............
View Napaman's profile
Napaman
5013 posts in 2243 days
#8 posted 320 days ago
really good article!
-- Matt--Proud LJ since 2007
