| Forum topic by Betsy | posted 55 days ago | 253 views | 0 times favorited | 11 replies | ![]() |
55 days ago |
I’m a jigsaw puzzle fan. It’s a nice way to relax. I’ve always framed my puzzles (I know that’s fake art – but oh well). I really like this particular puzzle http://www.puzzleworld.com/detail.aspx?ID=7007—- but not sure how I would frame/hang it. I’m thinking that I could mount it onto a backing board shaped like the puzzle – about 1” oversized – and then route an edge of some sort on it. But the issue I think would be weight. What do you guys think? -- Betsy - GO BUCKS! |
55 days ago |
Betsy, I am not sure what you mean about weight being an issue. I wouldn’t think that this puzzle, even with the backing, would weigh too much. I have framed and hung pictures weighing at least 30 lbs without any problem. If it were me I would mount it as you said and then wrap it with a frame. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
55 days ago |
Scott – i was just thinking that if the backing were solid (cherry, walnut, oak, etc.) it would weight quite a lot. Never have contemplated this type of “framing” job before. -- Betsy - GO BUCKS! |
55 days ago |
Betsy, I think Scott missed that it is not a rectangular puzzle, would love to see him frame that one! :-) I would think your idea would work, I fear that routing an edge on some of the inside openings might be difficult, or would you leave them solid perhaps?? or just cut them flush to the puzzle?? -- Fred, Springfield, Ma |
55 days ago |
Fred—- I’m thinking of leaving the small openings solid. But if I got brave I suppose I could cut out the small spaces with a coping saw and hand finish the edges. Just not sure—- this would be a first for me. -- Betsy - GO BUCKS! |
55 days ago |
Betsy, -- Ed Collinge- Edmonds, WA. |
55 days ago |
Well Betsy, why not treat the puzzle as if it were an inlay and inlay it into a nice solid piece. It would be hard right now I know, but you will heal up before long. -- . |
55 days ago |
Betsy, -- Berta in NC |
55 days ago |
Hi Betsy; I think I would cut the shape of the puzzle out of a piece of 1/4” plywood or M.D.F., leaving the sheet larger than the puzzle by whatever width border you want. Then I would veneer the border, using strips of veneers. You could miter the veneer where the end meet. Once that’s done, I would glue the puzzle to the sheet. Hope this helps. Lee -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
55 days ago |
My idea reflects that of BroDave. Use whatever wood suits the picture, and then cut it 1-2” wider than the curve and also 1” smaller than the curve, then router the outside edge to whatever profile suits you, and route a rabet on the inside edge. Back it up with cardboard or 1/4” luann. The only prob would be how the woods grain pattern runs…it might distract the eye and leave it looking bad. Maybe go with a dark wood (walnut) and stain it darker to eliminate the grain patterns? Whatever you do, it’ll look good! -- Bob Vila would be so proud of you! |
55 days ago |
you all have good ideas. I’m hoping to do a form of all I think. I am thinking of backing up the puzzle with 1/4 ply and then inlay the ply piece into a piece of hardwood—that will be about 1” larger all around and then route a decorative edge. I’ve never done the routing like this—- but I’ve got the router and a inlay bit/bushing. I’ll practice on some other small stuff before I do this. first I have to get the puzzle done! Thanks for the help. -- Betsy - GO BUCKS! |
54 days ago |
Betsy, My Mom is a puzzle junkie. 1000 pieces are a piece of cake for her- at age 82! I end up with a lot of puzzles that need framed. She recently did a border-less one that I simply framed with a rectangle frame and surface mounted the puzzle on the mat- leaving about 2” of mat exposed around the edges. The puzzle was also rectangular. For your puzzle, I think a nice oval or round frame would display the puzzle nicely. After it is together, coat the surface with puzzle-saver (decoupage). Then mount it on a suitable color mat using double sided tape. To reduce the weight, I would use foam board for the back of the frame. Even with this, by the time you get the glass, frame, etc. the weight can get impressive- depending on the size of the original puzzle. Looking forward to seeing the finished piece of art. Lew |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1142 |
1529 |
103 |
299 |
96 |
Woodworking Trade & Swap
211 |
Coffee Lounge
838 |
LumberJocks.com Site Feedback
256 |
