RIDGID Oscillating Edge/Belt Spindle Sander
Forum topic by knotheadswoodshed posted 06-30-2012 07:03 PM 2306 views 0 times favorited 12 replies Add to Favorites Watch
View knotheadswoodshed's profile
knotheadswoodshed
223 posts in 2257 days
06-30-2012 07:03 PM
does anyone have one of these or have thoughts on them?
I am needing a good spindle sander.
thanks
Randy
-- Randy - "I dont make mistakes, I make design change opportunities" www.knotheadswoodshed.com
12 replies so far
View Lifesaver2000's profile
Lifesaver2000
556 posts in 3196 days
#1 posted 06-30-2012 07:19 PM
http://lumberjocks.com/reviews/product/98
8 reviews, average 4.5 out of 5 stars
View Gene Howe's profile
Gene Howe
10718 posts in 3513 days
#2 posted 06-30-2012 07:22 PM
I have had one for 6-8 years. Use it for pattern making to fair up curves and for sanding curves in band saw boxes.
I like mine a lot. For $200, you can’t go wrong.
knotheadswoodshed
#3 posted 06-30-2012 07:23 PM
thanks guys…that clinches it..off th HD tomorrow to pick one up
View AHuxley's profile
AHuxley
727 posts in 3406 days
#4 posted 06-30-2012 09:00 PM
As long as you understand the lightweight/low HP limitations it is a great little OSS/OES. I will say they have made a lot of people realize how useful a OES can be and probably sold a lot of real OES as a result.
Just considered as a OSS it is the best you will do without spending over twice as much.
View Tyrone D's profile
Tyrone D
314 posts in 2417 days
#5 posted 06-30-2012 11:09 PM
I have one and I like it.
It can’t compete with a full size edge sander but the spindle sander is great.
-- --Tyrone - BC, Canada "Nothing is ever perfect, we just run out of time."
117168 posts in 3661 days
#6 posted 06-30-2012 11:32 PM
It’s a bargain for $200 it has things other osculating sanders don’t have like a belt sanding attachment and folding table top.
View Grandpa's profile
Grandpa
3260 posts in 2759 days
#7 posted 07-01-2012 02:44 AM
I have one and like it but you have to remember that the tabletop is plastic. the entire machine is plastic but it still works pretty well for me.
View Bobmedic's profile
Bobmedic
381 posts in 2886 days
#8 posted 07-01-2012 02:50 AM
Grandpa, The table top is not plastic it is painted aluminum. The base is plastic however it is very stable and has no vibration. Mine stays put with just the rubber feet.
Grandpa
#9 posted 07-01-2012 03:10 AM
hhhmmmm, looks like plastyic and flexes like plastic. I will have to check it out next time I get to the shop. I edge sanded some 2×8’s on it and they were heavier than the tools so it moved a little. felt like it was flexing. I do use it and like ti whether it is aluminum or plastic.
Not all plastics are bad.
View spidennis's profile
spidennis
6 posts in 2599 days
#10 posted 07-02-2012 08:53 PM
In researching this machine I heard you can stop it dead if you put too much into it? Presently I’m using the piece of crap (and taken off the market because it’s soooo bad) Dewalt 433 Belt sander and it’s equally bad edge sander stand. I thought I was stuck with this until I could afford a proper edge sander but then I found out about this model, and it has the spindle sander too?! cool. I’ll have to give this machine a try I think after seeing the comments here.
Gene Howe
#11 posted 07-02-2012 09:02 PM
I’ve never stopped mine using the belt sander/edge sander. I have stopped it sanding cut outs that get smaller towards one end and the drum I was using was too large to fit.
View rockindavan's profile
rockindavan
299 posts in 2720 days
#12 posted 07-02-2012 11:25 PM
The drums work awesome with no vibration. The belt sander on mine has a bit of vibration now and rocks a little bit. Other than this it works great.
