Brown Dye Turns Green...why?
Forum topic by BinghamtonEd posted 06-29-2012 04:45 PM 830 views 0 times favorited 2 replies Add to Favorites Watch
View BinghamtonEd's profile
2286 posts in 2306 days
06-29-2012 04:45 PM
I have some TransTint dark walnut water-based dye that I’ve been using with good results on several projects. I have noticed that if I get some drips on MDF, plywood, even some rags, sometimes it ends up dark in the middle and green around the edges. Anyone know why it turns green? Obviously it hasn’t been a problem in my work, just something I’ve noticed. I’ve used the dye on cabinet-grade plywood with good results too, it just looks green when you drip it on something, not flood the surface.
2 replies so far
View None999's profile
24 posts in 2122 days
#1 posted 06-29-2012 04:51 PM
My guess is that the green dye component is transported through the fibers more readily than the red dye component, perhaps due to particulate size.
-- None
View Tennessee's profile
2828 posts in 2451 days
#2 posted 06-29-2012 04:53 PM
I’m gonna GUESS that the dye contains a little copper sulfate as one of it’s colors, and when thinned enough, like on a edge, it reacts more with the oxygen in the atmosphere than a thicker coat, and it turns green.
That was quite a SWAG…
