What goes wrong with this Router - Does not start, burning smell & smoke.
Forum topic by woodworm posted 324 days ago 1350 views 0 times favorited 23 replies Add to Favorites Watch
View woodworm's profile
woodworm
14104 posts in 1757 days
324 days ago
Topic tags/keywords: router
Router Info : Wattage 2,100w, 10A, 220-240V Makita Model RP2301FC Made in Japan Year of manufacture 2009
The problem : I was cutting mortise (3/8”W x 2”L x 1-5/16”D) yesterday when I found that I had to stop many times. After I turned off the machine, I cleaned the wood chips in the mortise hole. Then I continued to use the machine but it did not start. I have to wait few minutes before I able to turn it on again. At one time after I completed one mortise I took about 10 mins rest with machine in the “OFF” mode but the mains power plug in the “ON” mode. After that I my nose caught very strong burning smell (like burning plastic/rubber) and I saw smoke came out of the motor casing. I immediately switch off the mains power plug.
Today I went to the shop (my second home actually which is 20KM from my home I live in) to test if the machine is still working. Yes I did start., but once I switched off the machine, I also had to switch the mains power plug off.
I just wonder how that happen. How could it be possible that current is running into the motor with the machine’s switch off? What goes wrong with my Router?
Thank you for reading. Any info is much appreciated.
-- masrol, kuala lumpur, MY.
23 replies so far
View GMman's profile
GMman
3882 posts in 1864 days
#1 posted 324 days ago
Check the bottom and if you get lots of sparks and a burning smell it’s done caput.
You can try to blow air in the bottom where the brushes are.
View Tennessee's profile
Tennessee
1089 posts in 681 days
#2 posted 324 days ago
I believe not only did you overheat the router due probably to failing motor windings, (that is why the overheat sensor kept tripping internally), it also sounds like you might have fused your router switch in the on position.
Either way, repairs are not feasible – get a new router.
-- Paul, Tennessee, http://www.tsunamiguitars.com
woodworm
#3 posted 324 days ago
GMman, I did notice sparks when I turned it to high speed. For this job, I just used the lowest speed.
View pintodeluxe's profile
pintodeluxe
1733 posts in 980 days
#4 posted 324 days ago
I agree with Tennessee, this is way more damage than worn brushes or something easily repairable.
Good luck
View Loren's profile
4873 posts in 1814 days
#5 posted 324 days ago
If you’ve used it in a table a lot, dust in the windings may have
contributed. Table use shortens router life.
View MrUnix's profile
MrUnix
256 posts in 365 days
#6 posted 324 days ago
There isn’t much that can go wrong with a router.. which is basically just a motor with a collet on one end. Most common cause of failure are brushes, bearings and getting all packed up with sawdust (particularly in the fan blades and between the rotor and windings). I’d pull it apart and check it out. Could be something as simple as just needing to be cleaned out or a $4 bearing gone bad.
-- Brad in FL - To be old and wise, you must first be young and stupid
View EdwardR's profile
EdwardR
52 posts in 420 days
#7 posted 324 days ago
I will make this easy on you. Electric motors have epoxy on the windings and when they get hot the epoxy melts and the windings short out. outside of rewinding the motor its trash. the smell is the tell tale sign. just sparks may allow you to clean the motor and brushes and move on. but that all familiar smell means R.I.P..
86979 posts in 1743 days
#8 posted 324 days ago
I tend to agree with Edward.
View renners's profile (online now)
renners
1881 posts in 1136 days
#9 posted 324 days ago
Surprising that a Makita would do that. They are usually workhorses.
If I was in your situation, I’d take it in to get it looked at and see if it was just the switch and brushes. If it was the armature, you might as well right it off.
From experience I know that if you go to the right place, you won’t get charged for it to be opened up if you buy a replacement from them, so there’s nothing to lose.
-- Do or do not, there is no try
GMman
#10 posted 324 days ago
I had on that did the same thing if you see large sparks just let it run and it will go dead.
View Schwieb's profile
Schwieb
1105 posts in 1628 days
#11 posted 323 days ago
Sounds like it is time to go shopping for a new router. I agree that this one is toast
-- Dr. Ken, Florida - Durch harte arbeit werden Träume wahr.
View KenBry's profile
KenBry
449 posts in 614 days
#12 posted 323 days ago
Yea, your tool is shot, but get ahold of Makita directly and explain it to them. They might be interested in your old unit to see what went south. I had a PC that had a screw inside come loose and get into the windings. They replaced the unit after 5 years.
-- Ken, USAF MSgt, Ret.
View Howie's profile
Howie
2449 posts in 1089 days
#13 posted 323 days ago
I’d junk it. Sounds like a good way to burn your shop down.
-- Don't rollerskate in a buffalo herd
woodworm
#14 posted 323 days ago
I love this router. It is just about 2ys old from the time I purchased it. Smooth plunge and with no vibration and further more it does not produce much noise or even I may call it very silent in the extreme case (as a comparision, I can even use it while my neighbor is sleeping). So today I sent it to the Makita’s Repair Shop. I will update you all with the results – good or bad not sure how long, 2 weeks maybe, a month or forever.
And at the same time, I order another one – PC since I need to use it with the guide bushing without the need to use adapter.
I am very2 grateful and overwhelm with the opinion, suggestions and info from you all. Thank you, thank you.
View dhazelton's profile
dhazelton
828 posts in 463 days
#15 posted 323 days ago
I apologize for asking the obvious, but were you you using it with a long extension cord of the wrong gauge? There has to be a reason it died so young.
