Question
Forum topic by RussellAP posted 06-29-2012 12:24 PM 855 views 0 times favorited 8 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2192 days
06-29-2012 12:24 PM
I have a HF jointer. I use it primarily to get the ‘fuzz’ off the WRC and make Adirondack chairs.
It snipes about an inch or so on each board I run through it.
Have I got it set up wrong or is that just the nature of the beast?
I don’t really mind it, a little 60 grit on a disk sander removes it.
8 replies so far
View Gene Howe's profile
Gene Howe
10125 posts in 3334 days
#1 posted 06-29-2012 12:40 PM
Russ,
I’ve spent many pleasant(?) hours attempting to eliminate the snipe on my 40 YO Craftsman. There are just way too many variables to screw around with, ever so slightly twisted wood, blade(s) too high, in feed/ out feed not properly aligned/coplanar…...identify the problem, fix it, and it doesn’t change the result, move to the next variable and on and on in circles. I just end up with lots of shavings on the floor and the same snipe!
I finally surrendered! I make sure the tables are co planar and the blades are set properly relative to the in feed and just live with the result.
My “V” sander is the go to machine for flatness now, anyway. The jointer and planer are just to get the pieces ready for truly flat on the sander.
View MrUnix's profile
MrUnix
6351 posts in 2104 days
#2 posted 06-29-2012 12:46 PM
You should not get any snipe on a properly set up jointer. The most common cause of snipe is the outfeed table being lower than the knives at the top of their arc.
View tyskkvinna's profile
tyskkvinna
1310 posts in 2891 days
#3 posted 06-29-2012 01:10 PM
It took me and a buddy roughly 2 hours to calibrate the jointer and now—if you use it properly—there is no snipe.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View jim454's profile
jim454
35 posts in 2318 days
#4 posted 06-29-2012 02:35 PM
I had a HF jointer never could get to cut square took it back bought a Jet. Like MrUnix said most common cause of snipe is the outfeed table being lower than the knives at the top of their arc.
View PurpLev's profile
PurpLev
8534 posts in 3554 days
#5 posted 06-29-2012 02:40 PM
a properly setup jointer should not have snipe (a thickness planer on the other hand…. ). it’s a very simple machine and unless something is not setup properly there is no reason for snipe on it.
RussellAP
#6 posted 06-29-2012 02:41 PM
I’ll try raising the outfeed table a bit.
View chrisstef's profile
chrisstef
17174 posts in 2912 days
#7 posted 06-29-2012 02:46 PM
You can try unplugging the machine and laying a piece of wood on the outfeed table covering the cutterhead but not touching the infeed table and manually rolling back the cutterhead, if the wood moves your outfeed table is too low. Adjust it until the knife just barely moves the wood.
View Loren's profile
9953 posts in 3553 days
#8 posted 06-29-2012 02:51 PM
Wood compresses and springs back a tiny bit on the
jointer… you can set the outfeed table at the same
level as the edge of the knife at the top of the arc
or a tiny increment below with the knife ever so
slightly proud. Sniping is caused by the knives being
too proud.
