Help post powder beetles in workbench
Forum topic by Dan posted 06-29-2012 03:22 AM 1731 views 0 times favorited 16 replies Add to Favorites Watch
View Dan's profile
Dan
106 posts in 3061 days
06-29-2012 03:22 AM
Topic tags/keywords: beetle workbench
I’ve been working on my 21st Century workbench for about 4 months on and off. I have gotten to the point where the bench is almost complete. I recently noticed little black bugs running around. I soon realized they were comming from my newly created bench. It is to big for me to move and try to fumigate. Anyone had any success with other methods. I am afraid all of the material I have is contaminated.
-- Will work for wood...
16 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2925 days
#1 posted 06-29-2012 03:29 AM
You will likely get a lot of responses to this query. I had this problem in a walnut chair I had sold. I tried several things that didn’t work and finally just threw a tarp over it and set one of those Raid bombs off under it. I then left it covered for a week. That has been several months ago, and I have seen no further signs of activity. Good luck and let us know how it comes out. I will definately use my method again as it appears to have worked. As a side note, the bomb did not harm the finish at all which suprised me.
View Dan's profile
Dan
#2 posted 06-29-2012 03:34 AM
Thanks for the reply. Maybe I can just fumigate the entire garage. Should I be worried about damaging my tools or wood?
View Scsmith42's profile
Scsmith42
125 posts in 2912 days
#3 posted 06-29-2012 03:38 AM
Dan, sterilization of wood is typically done with heat. Your best bet would be to build a box around your bench with celotex or equivalent foam board, and put a space heater inside (and below) on a thermostat. You want to get the core of the bench up to 133F or higher for at least 30 minutes. In order for the core to reach this temp, you will probably need to get the external surface of the slab up to 145 for 18 hours or so.
-- Scott, North Carolina, www.quartersawnoak.com
View Joseph Jossem's profile
Joseph Jossem
492 posts in 2503 days
#4 posted 06-29-2012 05:24 PM
the bayer poison at homedepot works but you have to get it in the holes or laquer thinner
freezing and heat also work but hard to do with that size
View Mainiac Matt 's profile
Mainiac Matt
8609 posts in 2563 days
#5 posted 06-29-2012 05:34 PM
that requirement is specifically to kill pine wood nematode….though I bet it probably kills a lot of other things as well.
I’m pretty sure there are fumigation standards to do the same thing…. but I have no experience with those processes.
-- I yam what I yam and that's all what I yam
View Tennessee's profile
Tennessee
2893 posts in 2749 days
#6 posted 06-29-2012 05:44 PM
Have done the tarp and bomb thing myself. It works, but I think I would also feel free to do the whole shop with multiple bombs at once. Never saw any damage with finishes on wood, but might want to coat your machined surfaces with wax before bombing.
View Dan's profile
Dan
#7 posted 06-29-2012 06:11 PM
Thank you all for your responses. If the bug bombs work it seams like the most plausible solution. Also might get some of those spiders that are hiding somewhere. Is there a specific type that I need to purchase? The garage is an oversized 2 car garage so I also need to figure out how many I might need. I can run by the hardware store today to take a look.
View KenBry's profile
KenBry
484 posts in 2682 days
#8 posted 06-29-2012 06:17 PM
Just remember that Bug bombs are FLAMABLE and the area you bomb will become highly flamable. There was a real good episode on Mythbusters. They of course had to go overboard and try to burn a house down with like 100 bug bombs. LOL..
-- Ken, USAF MSgt, Ret.
View Dan's profile
Dan
#9 posted 06-29-2012 09:39 PM
As long as I’m not running any open flames it should be ok right? After they are done I shouldn’t have to worry about open flames or am I missing something?
gfadvm
#10 posted 06-30-2012 01:13 AM
I’ve set em off in my shop and saw no aftereffects to the cast iron tables. The can will have recommendations for how many square feet per can.
View fussy's profile
fussy
980 posts in 3286 days
#11 posted 06-30-2012 04:07 AM
Dan,
Google Boracare. It’s a borate wood treatment. Home dopey has it so lowes and walmart probably do too. It works best in this situation, won’t stink up the place and won’t burn the house down.
Steve
View jmos's profile
jmos
905 posts in 2605 days
#12 posted 06-30-2012 03:08 PM
There’s a blog post on FWW about a pro who had 500bf of lumber stuck in an industrial deep freeze for three weeks to kill a beetle infestation. The charged him $100. Perhaps not terribly practical for you, but I thought I’d throw it out there as another option.
-- John
View Lazy_K's profile
Lazy_K
125 posts in 2425 days
#13 posted 06-30-2012 03:18 PM
hi; you can fume all you want to kill what you have right now, but your root problem is that your wood and your shop are too damp, when the wood is dry the powder post beetle cannot survive, try more heat in winter and a dehumidifier in the summer keep it dry and you will not have beetles.
-- Kai SaerPren
View Dan's profile
Dan
#14 posted 06-30-2012 04:09 PM
Thank you all for the input. I am going with a two pronged approach. I am going to fumigate and then spray. My shop is in my garage and I constantly have moisture issues. I am looking to move to a location with a stand alone shop that I can better control. I might have to get a dehumidifier in the meantime but need to find a way to keep it draining constantly.
View Snipes's profile
Snipes
223 posts in 2480 days
#15 posted 06-30-2012 06:09 PM
My understanding is the larvae are in the wood and killing the bugs is only part of the solution. You must heat treat to 140 degrees for six hours to kill. I would remove it from your shop asap.
-- if it is to be it is up to me
