How does one get a straight cut with a bandsaw?
Forum topic by hjt posted 330 days ago 2109 views 1 time favorited 22 replies Add to Favorites Watch
View hjt's profile
hjt
549 posts in 1310 days
330 days ago
Topic tags/keywords: bandsaw
Is it me or does everyone have problems cutting straight with a band saw? (Mine does not have a fence) I make my mark, draw my line and then line that line up to the blade. As I push the wood through I find myself having to move the wood left and right in order to keep the blade on (or at least NEAR) the line I’m trying to cut. What pray tell am I doing wrong??
-- Harold
22 replies so far
View Jeremy Greiner's profile
Jeremy Greiner
511 posts in 944 days
#1 posted 330 days ago
This was linked in another bandsaw thread .. it’s an amazing amount of information
http://www.youtube.com/watch?v=wGbZqWac0jU&feature=my_watch_later_videos&list=WLFDBDF675A22374DB
I plan on going through all the motions to set up my bandsaw like he shows as soon as I get some free time away from work.
-- Easy to use end grain cutting board designer: http://www.1024studios.com/cuttingboard.html
View Loren's profile
4898 posts in 1820 days
#2 posted 330 days ago
I do not have problems cutting straight with a band saw.
Getting the results you want is a matter of understanding how
the machine works and setting it up to do the task diligently.
View MonteCristo's profile
MonteCristo
2061 posts in 360 days
#3 posted 330 days ago
To put some flesh on Loren’s reply:
A well-tuned bandsaw with a good, sharp blade will cut straight and give a good finish. In my experience the quality of cut does not reach that of the top-end blades available for table saws, but you can come close.
You won’t be able to cut as straight freehand as you can with a fence so that’s your first job. It would also be a good idea to read up on bandsaw setup as there are a lot more things to set/adjust/worry about on a bandsaw (compared to a table saw) and you won’t be able to cut well until you get a handle on that stuff.
Good luck !
View hjt's profile
hjt
#4 posted 330 days ago
Thanks Jeremy, I’ll ckeck it out once I get home. My work computer does not have sound.
MC – I’m sure a fence would help out el’mucho. I’ll have to see if this saw has a fence option.
-- Harold
View jtbinvalrico's profile
jtbinvalrico
34 posts in 543 days
#5 posted 330 days ago
Centering the gullet of the blade on the wheel as opposed to centering the entire blade on the wheel is new to me…..anyone else have luck with doing that?
View jmos's profile
jmos
637 posts in 541 days
#6 posted 330 days ago
Harold, don’t think you have to buy a fence. You can, of course, and it will have a lot of advantages, the biggest being quick to adjust. But you can make your own and clamp it to the table.
-- John
View Derakon's profile
Derakon
83 posts in 339 days
#7 posted 329 days ago
I just asked this same question recently in this thread . You might find some useful information there. Good luck!
View Heisbert's profile
Heisbert
34 posts in 351 days
#8 posted 329 days ago
Here’s the jig you need to produce nice, straight cuts. Begin by cutting pieces and assembling them. Once you have all the parts assembled, position the fence on your bandsaw, and tighten the handle to secure the fence in place. Test-rip on a piece of scrap, and alternately loosen one machine screw and tighten the other until the fence is parallel to the cutting track of the blade. Be sure to loosen and tighten the screws the same amount to avoid bowing the fence. But if you work without fence, you may do it with your own convenient way as long as you feed the wood on a right track, though it would require good control when you feed the wood.
View jim454's profile
jim454
33 posts in 585 days
#9 posted 329 days ago
Here is link on how to How to Set Up a Bandsaw by Michael C. Fortune. How to Set Up a Bandsaw
View pintodeluxe's profile
pintodeluxe
1756 posts in 985 days
#10 posted 329 days ago
Try using a fence, and adjusting the fence for drift. A sharp blade helps.
Actually I only use my bandsaw for rough cutting, like taking the bark edge off a wide plank. Then its over to the jointer to true it up.
Same with curves. Rough cut to shape at the bandsaw, then pattern rout or sand to final shape.
View Tennessee's profile
Tennessee
1094 posts in 686 days
#11 posted 329 days ago
Jeremy, just watched the video. Learned a LOT of little things I was close on, but not dead on. Will cut better this weekend for sure! Thanks!!
-- Paul, Tennessee, http://www.tsunamiguitars.com
Gerald Thompson
192 posts in 406 days
#12 posted 328 days ago
The Snodgrass video on You Tube soleved all of my drift problems.
-- Jerry
View waho6o9's profile (online now)
waho6o9
2929 posts in 749 days
#13 posted 328 days ago
Good thread Harold, and thanks for the video Jeremy, and the link Jim454
View Alongiron's profile
Alongiron
333 posts in 865 days
#14 posted 328 days ago
You can have all the jigs and fences and videos you want but if you do not have the right blade…your in trouble. Get a wood slicer blade from highland woodworking and your bandsaw experience will change forever!
-- Measure twice and cut once.....
View hjt's profile
hjt
#15 posted 328 days ago
WOW! So many wonderful LJ’s willing to help a “rough cut” guy like me. This is so humbling and a major reason I LOVE Lumberjocks. Thank you all so much for your time and advice.
-- Harold
