band saw blades
Forum topic by alfonse posted 324 days ago 1111 views 0 times favorited 14 replies Add to Favorites Watch
View alfonse's profile
alfonse
6 posts in 507 days
324 days ago
Topic tags/keywords: question
what is the best brand blades i can buy . i have a 12 inch craftsman i use to cut out caricatures for carving.
14 replies so far
View AHuxley's profile
AHuxley
208 posts in 1487 days
#1 posted 324 days ago
You can’t really go wrong with Lenox or Starrett (Lenox doesn’t make anything smaller than 1/4” anymore). Lots of people like Timberwolf but I and many I know have had poor weld QC from them. They are high silicon steel so they start out sharper than standard carbon blades but dull much faster, if you have a need for that they are good, for most cutting they aren’t as economical as carbon. Although I love bi-metal blades that isn’t a saw that will handle them tension wise.
Spectrum Supply carries the full Lenox line, Iturra Designs Starrett and Lenox and woodcraftbands.com carries some of the Lenox line, all have given me good welds and good pricing though if woodcraftbands has the band you need in stock their prices are somewhat better.
Lets see how long the shills for sawblade.com take to show up…
View syenefarmer's profile
syenefarmer
332 posts in 1246 days
#2 posted 324 days ago
+1 on woodcraftbands.com. I’ve always gotten great service from them and their blades are also top notch.
View Rob Drown's profile
Rob Drown
638 posts in 1999 days
#3 posted 324 days ago
I have several Timber wolf blades and the welds are all very good. I have their 1” resaw and boy does it cut a board. 4” oak doesn’t even phase it on a 2 hp saw. Set it up pee Timber Wolf’s instructions.
-- The expectations of life depend upon diligence; the mechanic that would perfect his work must first sharpen his tools. Confucius, 经过艰苦的努力的梦想可以成真
alfonse
6 posts in 507 days
#4 posted 322 days ago
thank you for all your help
View MonteCristo's profile
MonteCristo
2060 posts in 354 days
#5 posted 322 days ago
A related question that is also worth asking is what type of blade is best for a given application / machine. Even Starrett or Lenox won’t help if it’s the wrong kind of blade. I agree pretty much with AHuxley on brands.
View woodklutz's profile
woodklutz
197 posts in 934 days
#6 posted 321 days ago
Huxley, you don’t know how good saw blade.com is, do you? I have been using their blades and they are great also the service price and shipping are far and away superior, quality is great. Your ignorant rant is uncalled for.
-- honing my craft one mistake at a time.
AHuxley
#7 posted 321 days ago
@woodklutz first I have used Haltbar blades along with every other major bandstock make and they are solid middle of the road blades. They are mainly focused on the metal industry though most bandstock manufacturers are. The issue is they tend to have very thick gauge backers which limit their use on hobby saws and though they have a new TCG carbide blade it is also on a very thick gauge backer even my Minimax would ecram trying to tension a 1” carbide Haltbar. The carbide blades also have pretty high TPI for their width further reducing their effectiveness in tall resawing work. Bottom line there almost always more choice and much more choice for wood friendly blades from other sources.
Regarding sawblade.com and their other feeder sites, since they have started using shills with ISPs registered in the Philippines to promote their sites on forums without identifying themselves I have no interest in spending money with them. They are effectively stealing from the forums they shill on, if they want to advertise, pay like everyone else. Then have their “posters” identify themselves as being “part” of the company. If these types of actions don’t bother you feel free to continue to patronize them, I for one will not. I have seen them on numerous forums starting in the last month or so, there are at least 4 on LJ.
Feel free to call me ignorant if you like, I am happy to compare bandsaw blade knowledge with you, if I come up short you are indeed the less ignorant man. If you feel that 12 word sentence was a “rant” I don’t now what would happen if you actually saw a rant. You chose to make it personal, I don’t see any need for that.
View ShipWreck's profile
ShipWreck
534 posts in 1918 days
#8 posted 321 days ago
I am a big fan of the Starret “Woodpecker” premium blades. Timber Wolf’s are a pretty good second choice for me.
View Bill White's profile
Bill White
2601 posts in 2126 days
#9 posted 320 days ago
I’m fortunate enough to have a blade company in my area. They cut and weld for the furniture and foam fabricating industry. They weld my blades from bulk stock.
93 1/2” blades (standard-not bi-metal) are about 7 bucks.
Check your area.
Bill
-- bill@magraphics.us
AHuxley
#10 posted 320 days ago
Bill, good advise most areas will have an industrial supply that welds blades, if one is buying prepacked blades they are over paying and there is only one prepacked blade I recommend and it is the Olson MVP bi-metal blade, it is unusual because of its thin gauge which makes it easy to tension, on small saws, to the high tension bi-metal needs. One must just check to make sure the supply house are using a quality bandstock, many will weld up cheap spring steel blades if they think you are only cutting wood as many of them outside the big wood use areas deal mainly with metal cutting and often don’t understand wood cutting well.
MonteCristo
#11 posted 320 days ago
@woodklutz
Calling AHuxley’s first reply a rant shows you don’t know the meaning of the word. It seems to me that he has done a lot of digging viz-a-viz bandsaw blades. Like me, he appears to have his opinions/favorites, but that does not constitute a rant, certainly not an ignorant rant. I think you owe him an apology.
BTW, I looked at sawblade.com out of curiosity. It looked like a pretty sleezy site to me (pressure to buy right from the get go) so I suspect AHuxley is right.
AHuxley
#12 posted 319 days ago
Just for reference I have no problem with that ecommerce site itself my only issue with them is the shills for them. They have been showing up on forums in the last month and circumventing the sites advertising. There are at minimum 4 accounts active of this site that do nothing but shill for that site and its feeder sites, that is where my admittedly snide comment at the end of my first post came from. Forums use advertising to make money, either in a profit oriented manner or to cover the costs of running the site in part or in whole. When shills come in a hawk their wares it “steals” the value of advertising on the site, it could put the site in a position to have to close or changes its approach, in that we all lose. If a retailer or manufacturer wants the advertisement pay for it and be open when you use an account to talk about it, otherwise is it like having people follow a newspapers delivery trucks and when they drop off their papers that person place ads in each paper.
View Woodbum's profile
Woodbum
180 posts in 1231 days
#13 posted 317 days ago
Alphonse: IMHO if there was one ” best ” blade, it would be the only one for sale. Use is a big determining factor. Resawing or curve cutting? Saw, radii size, availability, cost tolerance, length, ease of setup, drift and on and on . My two personal prefences in a 93 1/2” blade for a 14” Jet are: for resawing, the Woodslicer from Highland Hardware; and for general use, the All Pro or MVP blades in whatever width that my narrowest radius cut calls for. But, that being said, Carter also makes a good line of curve cutting blades. But these are just my personal preferences arrived at after much trial and error. Hope this helps some.
-- Improvidus, Apto quod Victum-- Improvise, Adapt, Overcome
View fussy's profile
fussy
963 posts in 1217 days
#14 posted 317 days ago
Try what MichaeL Fortune and other reknowned pros use. Try www.bcsaw.com in Toronto. They use Stasrrett stock, weld quality is excellent, and at under $10.00 each, they are inexpensive. The carbon steel is best, probably no larger than 3/8” for your saw. The right tooth configuration is paramount aand they have them all. They are carbon steel, and I have found they work quite well.
One aside here: bandsaw blades don’t last forever. They get dull, quickly it seems. Don’t throw them away. Go to a site like www.woodgears.ca and learn how to quickly and easily sharpen them. I bought 10 blades last time from BC and am still on the first as I learned how to sharpen. I am starting to wonder if I shall live long enough to use them all.
Steve
