How to Widen the Dowel-it Jig
Forum topic by NedG posted 06-28-2012 09:42 PM 1103 views 0 times favorited 1 reply Add to Favorites Watch
View NedG's profile
NedG
56 posts in 2280 days
06-28-2012 09:42 PM
I have the Dowel-it Jig, and want to use it on table legs that are wider than the jig opens up to. Does anyone have a good idea this can be done by modifying this jig, or possibly another means to accurately dill holes in a wide table leg. Thanks very much. Ned
1 reply so far
View DS's profile
DS
2894 posts in 2386 days
#1 posted 06-28-2012 11:10 PM
Use a measuring tape, burn an inch, mark it with a pencil, use an awl, or, punch tool to make a pilot hole dimple so your drill won’t wander. Take your time, it’ll work out.
If you want a jig to help out, any flat scrap of wood will work. Measure and drill it carefully like the above proceedure. Then, use it as your template to drill the rest. You could even glue a fence board to the edge of the jig to help in positioning it. I use this kind of jig all the time to drill for knobs and pulls on cabinets.
