Getting a true straight edge on irregular sizes of wood
Forum topic by RangerTracy posted 325 days ago 757 views 0 times favorited 8 replies Add to Favorites Watch
View RangerTracy's profile
RangerTracy
6 posts in 353 days
325 days ago
Does anyone have any suggestions on how I can put a true straight edge on an irregular piece of wood that is about 1” x 2” x 24” and do so only with a table saw?
8 replies so far
View SASmith               's profile
SASmith
1367 posts in 1154 days
#1 posted 325 days ago
Would this work for you?
Or how about this! ?
-- Scott Smith, Southern Illinois
12051 posts in 1508 days
#2 posted 325 days ago
steve nailed it
with both ways
RangerTracy
6 posts in 353 days
#3 posted 325 days ago
Thanks so much for the tip! Now it’s off to the shop!
View TechRedneck's profile
TechRedneck
635 posts in 1024 days
#4 posted 325 days ago
Good Ideas!
I have a jointer, however this should work well with troublesome boards or irregular boards. This is going on my “jig” list.
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
View Doss's profile
Doss
777 posts in 431 days
#5 posted 325 days ago
steve nailed itpatron
I think Scott got it right.
Just messin’ with you patron.
You could also set up a jointer saw sled. I’m pretty sure you can find that sled if you use those key words.
-- "Well, at least we can still use it as firewood... maybe." - Doss
#6 posted 325 days ago
sorry scott
thanks doss
View gfadvm's profile
gfadvm
6621 posts in 857 days
#7 posted 325 days ago
SASmith, thanks for the links. I use the second method but never thought of putting the straightener ON TOP of the board. I’ve been doing it upside down all this time!
View KenBee's profile
KenBee
109 posts in 802 days
#8 posted 324 days ago
Not having a table saw I built jigs to use my circular saw to cut straight edges or accurate board widths. In fact I have 13, 25, 37 and 49 inch length jigs to use with my circular saw, Rockwell VersaSaw, jig saw and router for cutting to size and/or cleaning up the edges of boards. The jigs for my circular saw can be used for either side of the saw shoe plate and the router jigs are set up to use with a router base plate specifically for that jig.
-- If it won't fit get a BIGGER hammer.
