Finish On Top of Danish Oil?
Forum topic by BigMig posted 356 days ago 744 views 0 times favorited 6 replies Add to Favorites Watch
View BigMig's profile
BigMig
109 posts in 811 days
356 days ago
Topic tags/keywords: watco danish oil danish oil
I made a small box using common maple and finsihed it with 3 applications of Watco Danish Oil. Is it possible to apply anything on top of the Danish Oil? Is there anyhting I should specifically stay away from because of the Danish oil?
-- Mike from Lansdowne, PA
View levan's profile
levan
319 posts in 1177 days
#1 posted 356 days ago
We always used lacquer over watco. Just make sure it is completely dry. We normally used just one coat of watco, with lacquer sealer and finish on top.
-- Lynn "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
14937 posts in 2416 days
#2 posted 356 days ago
You can put pretty much anything over the Watco once it has cured. I have put wipe-on poly over it many times.
View horky's profile
horky
63 posts in 1128 days
#3 posted 355 days ago
I have successfully used: water based poly, oil based poly, a mixture of DO and Poly (50/50). All worked well. But as stated above, let the DO dry for several days.
View Ripthorn's profile
Ripthorn
506 posts in 1183 days
#4 posted 355 days ago
A look that I love is to put a coat of paste wax on top of watco. I did this on a mahogany cabinet and it looks phenomenal.
View Gene Howe's profile
Gene Howe
3217 posts in 1626 days
#5 posted 355 days ago
As stated above, almost any finish will work on thoroughly dry Watco. Lately, I’ve been mixing it 50/50 with Marine varnish or poly. Makes a nice wipe on finish.
BigMig
#6 posted 355 days ago
Thanks for the feedback. I may try one of the ideas you guys posted.
