Boxmakers - how do you cut the top off?
Forum topic by lumberjoe posted 06-28-2012 04:23 PM 2266 views 0 times favorited 22 replies Add to Favorites Watch
View lumberjoe's profile
lumberjoe
2899 posts in 2210 days
06-28-2012 04:23 PM
I am building a box now and have it ready for glue up. I do not have a band saw and need to cut the top off of the box when it is done being glued. I’ve read you can do it with a table saw. Is that safe? are there any jigs needed to make it safe? I am thinking about making a tenoning jig for my cross cut sled and am hoping something Like that will work
22 replies so far
View Jeff's profile
Jeff
428 posts in 3156 days
#1 posted 06-28-2012 04:32 PM
I use the table saw. To be perfectly safe fill the kerf with a spacer and clamp it together.
View crank49's profile
crank49
4030 posts in 2933 days
#2 posted 06-28-2012 04:40 PM
Its best to leave a small bit in the middle that you cut by hand after the table saw. Helps avoid pinching the TS blade.
If it’s a big box, like over 7”, then you would have to clamp a filler in the first cut and cut all 4 sides.
In either case, always keep the same siide against the fence.
View Maveric777's profile
Maveric777
2693 posts in 3039 days
#3 posted 06-28-2012 04:42 PM
I cut mine with a table saw as well. The trick is to raise the blade up just a smidgen shy of the actual depth of the sides. Then I simply use a razor blade to cut the rest of the lid off….
-- Dan ~ Texarkana, Tx.
View gfadvm's profile
gfadvm
14940 posts in 2652 days
#4 posted 06-29-2012 01:44 AM
I don’t trust my bandsaw to cut straight enough so I do it like Dan suggests but leave a little more than a “smidgen” and then cut through with my HF Japanese pull saw.
View tyskkvinna's profile
tyskkvinna
1310 posts in 2948 days
#5 posted 06-29-2012 01:48 AM
I use my TS to do it all the time—I have made some sticks that are a hair bigger than the kerf of my blade and I stick them in the middle after I cut a side. Then just masking tape. Cut one side, stick the kerf-stick in, tape it on, do the opposite side, repeat until all four are done.
It is terrifying at first (because it’s just an unusual way to run something through the TS) but after doing it a few times it’s really quite easy.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
lumberjoe
#6 posted 06-29-2012 01:49 AM
That was my idea. I was going to leave about 1/16th. Will a coping saw followed by some strategic sanding suffice to clean up the rest?I don’t have a pull saw, but I guess another 10$ won’t kill me
View PurpLev's profile
PurpLev
8534 posts in 3611 days
#7 posted 06-29-2012 01:51 AM
TS – the trick is not to cut through – then you don’t need spacers, or masking tapes and whatnot.
if the box material is 1/2” thick – then you set your saw to cut 15/32” or 31/64” – the number is not crucial as long as it’s a hair under 1/2” (it’s ok if you cut through in a few spots as long as you don’t completely cut it off free) – then once you are done “grooving” the top “off” you can use an exacto-knife or a chisel and free that webbing of wood still holding the top to the box itself easily – safe, and easy.
lumberjoe
#8 posted 06-29-2012 01:59 AM
It is terrifying. I am envisioning the box falling apart on one of the cuts and my palm meeting that brand new unguarded infinity blade. There are obviously a few ways to do this. I am kind of partial to the kerf stick method right now as I have a lot of those that I cut for the splines anyway.
Purple Lev, That also sounds like a good idea, however having any unfilled blade kerf 3/4 around the piece and send it through something spinning violently that wants to destroy it while it is being held together by 1/64” of wood fibers still makes me nervous. Possibly unreasonably so, but it does none the less.
View jumbojack's profile
jumbojack
1674 posts in 2586 days
#9 posted 06-29-2012 02:16 AM
I have successfully cut the tops off with the table saw many times. I have enough 1/8 scrap laying around to fill the kerf with. Cut the first two sides and fill the kerfs and cut the other two. I have never felt threatened.
tyskkvinna
#10 posted 06-29-2012 02:18 AM
I have done the “cut just barely the thickness” before and I just was not fond of it. -shrug- Each to their own. I found that I never get a smooth cut when I try to separate them but putting the kerf-stick in is super smooth and easy once I figured out what I was doing.
gfadvm
#11 posted 06-29-2012 03:15 AM
Lumberjoe, I made a “flattening board” to level box legs,etc. This is what I use after sawing the top off. Quick, simple, and it comes out PERFECTLY flat. I just glued 100 grit paper to a 16” wide piece of Masonite, clamp it to the table, and rub the cut edge across it until flat and smooth. I have used the tape andkerf stick successfully but I have also wrecked a box with this method and I hate trashing a project that late in the game. I am comfortable with my technique and will likely stick with it.
View Gary's profile
Gary
9322 posts in 3395 days
#12 posted 06-29-2012 03:38 AM
I send mine to Dan, (Maveric777) and let him cut it off. Keeps my fingers safe
Maveric777
#13 posted 06-29-2012 11:59 AM
LOL Gary…. Now that’s smart thinking my friend… lol
View Gene Howe's profile
Gene Howe
10341 posts in 3391 days
#14 posted 06-29-2012 12:20 PM
I’m always up for a new way to do something. So, I’m about to try a slitting saw mounted in the router table. Still, I’ll only cut part way through and do the final with a pull saw.
Slitting saw was originally intended for making contrasting cuts in corner reinforcement flitches cut with the TS.
View KenBee's profile
KenBee
109 posts in 2597 days
#15 posted 06-29-2012 02:42 PM
Not having a band saw or table saw I, like Gene Howe use my router table to cut box lids off with either a slitting saw or a 1/16th slotting router bit. I also do not cut all the way through to prevent binding and use an xacto knife to complete the cut. I find it to be an accurate, safe and quick way to separate the two parts of a box.
-- If it won't fit get a BIGGER hammer.
