Zero Clearance Inserts
Forum topic by Dusty56 posted 325 days ago 754 views 0 times favorited 11 replies Add to Favorites Watch
View Dusty56's profile
Dusty56
10496 posts in 1853 days
325 days ago
Topic tags/keywords: resource tip tablesaw zci
http://www.ptreeusa.com/edirect_062612.htm
I got a couple of these for my JET cabinet saw awhile ago and found them to be quite good quality and @ only $10 each (for my saw) , I really didn’t want to make my own !!
Mine are made from the UHMW compound. Slick and still virtually no signs of wear.
I hope this helps someone else in need : )
I did not invest in the splitters though , so I can’t comment on them.
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
11 replies so far
View amagineer's profile
amagineer
1013 posts in 763 days
#1 posted 325 days ago
Thanks for the info, I will take a look at it.
-Don
-- Flaws are only in the eye of the artisan!
View knotscott's profile
knotscott
4181 posts in 1541 days
#2 posted 325 days ago
Sorry to be a party pooper, but the UHMW material at this thickness is not suitably stiff as a table saw insert and can adversely effect your cut quality due to flexing. It’s also quite prone to warping if not mounted to a stiffer substrait. I’d opt for the phenolic, steel, aluminum, baltic birch, or even hardwood over the UHMW.
View Roger's profile
Roger
9191 posts in 970 days
#3 posted 325 days ago
Thnx for the link. I’ve been making my own out of mdf, and they work gr8.
View John 's profile
John
193 posts in 1567 days
#4 posted 324 days ago
I used to make mine out of UHMV but since I moved, I lost contact with my supplier and it’s not easy to get here. I’ve been making mine out of fall off Corian ot surrell and that has been working GREAT. I never had a problem with UHMV saging though.
-- John
Dusty56
#5 posted 324 days ago
Hi knotscott , I must have lucked out with mine…no problems at all : )
I agree that the phenolic is a stiffer product , but for my money , I am quite happy with the UHMW insert.
Maybe I’m not ripping short enough pieces , or pressing down too hard on it to make it deflect ? Mine are still as flat as the day they came….could be the nearly constant temperature of my basement. I don’t know : )
View redryder's profile
redryder
1579 posts in 1267 days
#6 posted 324 days ago
Those prices would be hard to beat. Might be worth a try. Thanks for the link….............
-- mike...............
View alexdom_89's profile
alexdom_89
80 posts in 462 days
#7 posted 322 days ago
tried to order some today but i guess the sale was over so they are back to 29 bucks each
View NiteWalker's profile (online now)
NiteWalker
1467 posts in 742 days
#8 posted 322 days ago
You have to enter code: zero3 in the box at checkout.
View SouthpawCA's profile
SouthpawCA
237 posts in 1399 days
#9 posted 322 days ago
I totally agree with knotscott. I purchased 2 of these. Within about a week the first one I installed started warping. The directions say to flip it over for awhile to get rid of the warp. It’s been 2 weeks now – still warped. I figure I’ll use the 2nd one if I have to for some reason. Money wasted as far as I’m concerned.
-- Don
Dusty56
#10 posted 321 days ago
What saw model did you get yours for ?
I have the JET cabinet saw and haven’t had any issues with either of my inserts.
John
#11 posted 321 days ago
There must be different grades of UHMV cause I never had a problem with them. BUT, I didn’t get them online, I bought a quarter sheet from a plastics shop where I used to live and made my own. Maybe the ones that are online are too thin.
-- John
