Does Steel Wool Last Forever?
Forum topic by Eric posted 502 days ago 205 views 0 times favorited 4 replies Add to Favorites Watch
View Eric's profile
Eric
784 posts in 679 days
502 days ago
Topic tags/keywords: steel wool
Okay, so I just bought my first bag of steel wool (grade 00000). It seems as if it would be hard to tell when you’d have to throw out the steel wool you’re using. Can you theoretically use one batch of steel wool your whole life? I’m also assuming I need to protect my steel wool from the elements and keep it in a dry place, to prevent rust.
Thanks for any tips you have!
-- Eric at http://adventuresinwoodworking.com
20707 posts in 718 days
502 days ago
The major problem with steel wool is moisture which causes it to rust. If you keep it dry then it has an indefinite shelf life.
View Blake's profile
Blake
2760 posts in 770 days
502 days ago
It will load up with residue with use. Depending on how you are using it, it works best with some kind of liquid medium (like WD40 to clean rust off steel) to carry away the particles. So it gets pretty gross after a few uses. It also breaks down very quickly with use and doesn’t “cut” as well after just a little while. It is just like sandpaper. It is a disposable product. Why do you ask, is it very expensive in your corner of the globe?
7654 posts in 1114 days
502 days ago
Here is a steel wool fun fact:
When you were a kid, did you ever take a piece and touch both posts of a 9-volt battery to it? (Hint: be prepared for fire.)
View edp's profile
edp
103 posts in 856 days
502 days ago
I gave up with the steel wool about 3 years ago (for wood projects). The down side of the stuff is that it has a tendency to leave slivers behind, trapped in the wood. Not necessarrily a bad thing until that area comes into contact with moisture. When that happens, you have created iron oxide. Better known as rust. Not exactly the appearance most of us are going for in our woodworking. I purchased a carton of the purple scotchbrite pads instead. Now this stuff does seem to last forever. In the approximately 3 years I have been using it I have yet to consume the first half of the box. And….yes, I do use it constantly. It is my final prep before stain. My rub between coats of lacquer and my final rub out on the top coat when the gloss is just a tad too high.
Ed
-- Come on in, the beer is cold and the wood is dry. www.crookedlittletree.com
