How do I get the red berry stain out of the wood?
Forum topic by Don posted 330 days ago 802 views 0 times favorited 4 replies Add to Favorites Watch
View Don's profile
Don
392 posts in 1412 days
330 days ago
Topic tags/keywords: question
Someone left strawberries on a clients cutting board and now she has a nice red stain on it.
Any ideas on how to get rid of the stain??
Thanks….Don
-- -- Don in Ottawa, http://www.donebydon.ca
View madts's profile (online now)
madts
662 posts in 509 days
#1 posted 329 days ago
Use wood bleach, AKA oxalic acid. Just follow instructions
-- Thor and Odin are the greatest of Gods.
View Don W's profile
Don W
9952 posts in 737 days
#2 posted 329 days ago
call it patina instead of a stain. It raises the value of the board. or do as described above.
View bobsmyuncle's profile
bobsmyuncle
105 posts in 860 days
#3 posted 329 days ago
Try it first with hydrogen peroxide. It’s a mild organic stain remover. I use it to get berry juices out of my Formica counters. I also use it to remove organic stains from upholstery fabrics. After it does its thing, it converts to water and evaporates away.
Oxalic acid has its own dangers and must be removed before you use it for food use. Even sanding an un-neutralized oxalic acid treated wood can cause respiratory problems.
View Tennessee's profile
Tennessee
1089 posts in 684 days
#4 posted 329 days ago
Another problem with oxalic acid is it only removes the first few thousandths of an inch of the stain. If you go back to resand, you might re-reveal the stain, if it went deep enough.
-- Paul, Tennessee, http://www.tsunamiguitars.com
