bandsaw table top turning palms black
Forum topic by Blackie_ posted 06-25-2012 06:46 PM 1406 views 0 times favorited 12 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4883 posts in 2476 days
06-25-2012 06:46 PM
Anyone else becides me have this problem? Everytime I get on the bandsaw for working a project, when cutting projects on the bandsaw rubbing palms across the table turns them black and won’t wash off.
Thanks
Randy
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
12 replies so far
#1 posted 06-25-2012 06:57 PM
Havent had that problem as of yet Randy Dirty table maybe lol. Na just the metal on the table. Guess they call you Blackie for a reason LOL But to be serious I bet its the swet from your hands that makes this happen. The acids in our skin reacts to different metals.
-- http://www.landwoodworks.com (L an D Woodworks)
View MrUnix's profile
MrUnix
6586 posts in 2163 days
#2 posted 06-25-2012 07:04 PM
If your table is good and waxed, you should not have any problems. I would try scrubbing it down with some WD-40 and a scotch-brite pad followed by a good waxing. Some prefer paste wax, I happen to like Maguiar NXT synthetic wax as it seems to hold up a little better. Whatever you use, make sure it doesn’t have any silicone in it.
View JuniorJoiner's profile
JuniorJoiner
485 posts in 3404 days
#3 posted 06-25-2012 07:19 PM
are you cutting mesquite, because that will turn your hands black. I just spray a machine top with jigaloo(after i clean it) and i never have the problem again.
-- Junior -Quality is never an accident-it is the reward for the effort involved.
View Dallas's profile
Dallas
3599 posts in 2451 days
#4 posted 06-25-2012 07:31 PM
Is there any hair growing in the palms?
View PurpLev's profile
PurpLev
8534 posts in 3612 days
#5 posted 06-25-2012 07:34 PM
clean the tables and wax them with paste wax – cheap, effective (in more than one way).
if that does not stop the blacking – it might be the wood you are using (oak/mahogany/anything with tanic acids will blacken your hands and does not wash off)
View Jim Jakosh's profile
Jim Jakosh
20280 posts in 3069 days
#6 posted 06-25-2012 07:38 PM
I guess that could be coming from raw aluminum which will turn your hands black, but it come off with hand cleaner. I coat all my surfaces- cast iron, steel or aluminum with a coat of Butchers floor wax 2-3 times a year just to keep wood gliding nicely . I have that same saw you do and never got any black from it….........Jim
Blackie_
#7 posted 06-25-2012 10:21 PM
The woods I was cutting were, Walnut and Oak, don’t think it was due to sweat as my shop is ACed I’ll do what everyone suggested clean table and put some wax down on it.
Thanks all
View Tomj's profile
Tomj
204 posts in 2346 days
#8 posted 06-26-2012 12:57 AM
I would use any wax without silicone in it. I wouldn’t use WD40 because I believe that has silicone in it which can cause problems with finishing. Good luck.
MrUnix
#9 posted 06-26-2012 02:00 AM
Tomj wrote ”I wouldn’t use WD40 because I believe that has silicone in it
From the WD-40 FAQ:
Q: What does WD-40 contain?
A: While the ingredients in WD-40 are secret, we can tell you what WD-40 does NOT contain. WD-40 does not contain silicone, kerosene, water, wax, graphite, chlorofluorocarbons (CFCs), or any known cancer-causing agents.
WD-40, a straight-edge razor blade and scotch-brite pads are first in line for cleaning table tops. It will take care of most gunk and surface rust problems you may have. Put the pad on a random-orbital sander for stubborn areas, and keep the table/pad well lubricated.
View Tomj's profile
Tomj
#10 posted 06-26-2012 05:16 AM
I’m assuming that was from the WD-40 website. I always thought it had silicone in it which was one of the ingredients that helped displace/repel water. I stand corrected. Thanks for the info.
View Roger's profile
Roger
20923 posts in 2768 days
#11 posted 06-26-2012 11:36 AM
Yup, Walnut & Oak will do that. I agree with others about your top/s on any shop equipment. I use Johnsons paste wax anytime I notice any “drag” on any boards.
Blackie_
#12 posted 06-26-2012 12:01 PM
I sometimes used plan wax paper and rub it across the table tops and it makes all smooth just not sure what’s on the wax paper surface.
