Cutting tennons
Forum topic by Mike posted 330 days ago 830 views 0 times favorited 12 replies Add to Favorites Watch
View Mike's profile
Mike
60 posts in 378 days
330 days ago
Hi all, what’s your preferred method for cutting tenons? I know there are tenon jigs for table saws, you can make them on a band saw, probably a router table could be used, not to mention hand cutting/ chisel…I’m interested in knowing how people make them, what they prefer and why. I’m betting this discussion will uncover some cool modifications or adaptations, as well as be a learning base for people like me who are trying to master the good ole Mortise and Tenon joint.
12 replies so far
View Loren's profile
4880 posts in 1816 days
#1 posted 330 days ago
Open tenons/slip joint on the table saw.
Invisible tenons table saw for the shoulders, cheeks
on the band saw or table saw. Depends on the length
and weight of the board being tenoned.
View oluf's profile
oluf
252 posts in 1207 days
#2 posted 330 days ago
Dado blade on the radial arm saw. Safe and true.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View tenontim's profile
tenontim
2129 posts in 1913 days
#3 posted 330 days ago
Tenon jig on table saw or I have a home made horizontal mortiser, that also cuts tenons, that I use on long boards. When all else fails, I mark them out and use a Japanese tenon saw.
-- Tim-- http://www.tmuli.com
View madts's profile
madts
662 posts in 508 days
#4 posted 329 days ago
Tenoning jig on tables.
-- Thor and Odin are the greatest of Gods.
View gfadvm's profile
gfadvm
6626 posts in 858 days
#5 posted 329 days ago
shop made tenoning jig on the tablesaw
View DonnyD's profile
DonnyD
49 posts in 342 days
#6 posted 329 days ago
tenon jig on table saw, rides the fence
View ShaneA's profile
ShaneA
3963 posts in 767 days
#7 posted 329 days ago
As mentioned…length, width, depth and quantity have a factor into the method.. Just a few smallers ones I will nibble away at TS. More quantity small ones, a tennon jig. Long boards SCMS and band saw/hand saw combo. Mortises on benchtop mortising maching unless too big. Then forstner and chisels. Many ways to skin that cat.
View Cato's profile
Cato
642 posts in 1481 days
#8 posted 329 days ago
I don’t do a ton of mortise and tenon work, so I make mine on the router table and cut the mortises with a router as well.
A little quick work with a rasp and my shoulder plane and the square tenon will have its rounded shape for the mortise.
I may get a tenon jig for the TS one of these days if I continue with much furniture work, but for now the routers work very well for this.
View rockindavan's profile
rockindavan
254 posts in 804 days
#9 posted 328 days ago
I use a slot mortiser for the mortises, then square them up. For the tenons I use the router table. I cut all the pieces to the exact length I need including the tenons. Then I use a marking gauge to mark out the shoulders. I cut all but 1/64 – 1/32” up to the shoulder. I fit it the thickness first then width. After it fits well I trim off the extra material using the marking gauge line as reference with chisels. Might sound like extra work, but it ends up perfectly square as long as the stock is square. I aways seem to end up with it not ending up perfect without using a marking gauge. The TS seems to have chipping and the router table and TS seem to end up with a corner or two slightly off.
View AKSteve's profile
AKSteve
412 posts in 472 days
#10 posted 327 days ago
I actually cut all of my Tenons by hand. they are really quite easy. I use a Japanese saw for a really fine cut. And for the Mortises, it just depends sometimes I will just chisel them, other times I will use a drill and then clean up with a chisel and rasp.
-- Steve - Wasilla, Alaska
View Sylvain's profile
Sylvain
465 posts in 668 days
#11 posted 326 days ago
have a look at this :
http://paulsellers.com/2011/12/mortise-and-tenon-under-10-minutes/
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View pintodeluxe's profile
pintodeluxe
1739 posts in 982 days
#12 posted 326 days ago
I like a dado blade on the table saw. The reason for this—- you never have to stand a workpiece on end to pass it through the blade. With a dado blade, the workpiece is always flat on the tablesaw.
If you use a sacrificial fence and a wide dado set, you can make very clean cuts. Works great for through mortise and tenons.
