Blade for ripping 8/4 stock?
Forum topic by Scott Wilson posted 144 days ago 222 views 0 times favorited 12 replies Add to Favorites
View Scott Wilson's profile
Scott Wilson
20 posts in 293 days
144 days ago
I’m working on some cutting boards (the WW’s endgrain style) and I am really taxing my Ridgid TS3650 saw when ripping the 8/4 purpleheart and maple. I am new to this saw and have replaced the stock blade with the Forrest WWII thin kerf blade and wired it to 220. Even with an extremely slow feed rate (read “watching paint dry” slow) the saw bogs down to almost stopping. Well, actually I have stopped it a time or two. Is there a better blade for ripping this thick stock or am I expecting too much from the 1 1/2 hp motor on the 3650? I should also note that this issue notwithstanding, I love the saw. The saw and the blade work like a dream on the sheet goods and 3/4” lumber that I have cut. Super smooth, glue-ready edges for the most part. I may just be pushing it to do something it was not meant to do.
-- Scott Wilson - Bear with me, I'm learning!
View rtb's profile
rtb
204 posts in 250 days
144 days ago
I don’t know scott. I have the same saw and untill a few days ago was using the blade that comes with it. My experience has been that any time that I bog the saw down its feed related. Recently I have been ” hoging out” landscape timbers with my dato set at 7/8 wide x 1 inch deep. This quite hard wood (for a soft wood) and must be fed slowly but dosn’t stall unless I get too pushy. perhaps you have a week motor or some other mechanical problem that only shows up under this kind of stress. Like you I love this saw and wouldn’t even consider anything else.
View Llarian's profile
Llarian
37 posts in 144 days
144 days ago
I just made a few of these with the same table saw. While its a little underpowered, I gfot through it without too much issue other than a little burn on the side of the rock maple. (110v power)
I’m using a Freud LU87R010, which seems to be the trick. My combo blades don’t handle it well at all, but I got a good smooth rip using that blade.
-- Dylan Vanderhoof - New woodworker in training. =)
Scott Wilson
144 days ago
I guess I should try a true rip blade and see what that does. I just called the Ridgid service center in my area and they said I could bring the motor in and they could test the load capacity on the spot to make sure that is not the problem.
9878 posts in 359 days
144 days ago
Scott,
I use the WWII full kerf blade on my 1 1/2 hp Craftsman saw and it does tend to slow down on 8/4 maple but if I keep the feed steady it will rip it just fine. I think that taking the motor in for a test is the best approach as it should be capable of ripping the maple, especially with the thin kerf blade.
View John Ormsby's profile
John Ormsby
194 posts in 274 days
144 days ago
Ripping calls for as few teeth as possible. You might try the Freud 10” 18 tooth industrial rip blade.
I use a 12” 14 tooth on my saw and it will cut just about anything.
You risk kick backs and heating the blade if it has too many teeth.
Freud Blade number LM71M010 for 5/8” arbors
Freud’s Lu think kerf series blades have too many teeth to rip safely for extended time and thick boards.
Here is a link for Freud blades http://www.freudtools.com/c-8-industrial-blades.aspx
There are other blade companies out there who sell good ripping blades. The key is to make sure they have deep gullets and few teeth.
-- Oldworld, Fair Oaks, Ca
View Tony Z's profile
Tony Z
151 posts in 327 days
144 days ago
Maybe it’s the fence? Try checking the fence to make sure it’s parrallel to the blade.
-- Tony, Ohio
View Loren's profile
248 posts in 184 days
144 days ago
if you are using an underpowered saw you’ll want to get a blade without
too many teeth, a thinner kerf, and very sharp.
A lot of struggle you’ll get with contractor saws is because of the
blade binding and burning the wood as the cut releases internal
tension in the stock.
My preference is to snap a line, bandsaw to it, let the wood sit overnight,
the joint one edge and rip it parallel on the TS.
Sounds like a lot of work, but binding and burning isn’t much of
a problem for me this way. BTW – I have a cabinet saw so power
isn’t a problem but tension in wood is always a problem if you don’t
plan for it.
Also a splitter the same thickness of the blade helps a lot, as do featherboards,
a parallel fence (I used to set it out by 1/32” but no longer do so), and using
a facing on the fence that ends at the back of the blade, as with European saws.
-- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online businesses - http://COPYMATCH.COM
View closetguy's profile
closetguy
113 posts in 429 days
144 days ago
Scott, I have the TS3650 and work with 8/4 for butcher block boards. I had a lot of problems with the saw laboring and scortching the wood using the Wood Worker II for cross cutting and the CMT glue line rip. These were fairly new blades. I recently purchased the Freud 80 tooth Ultimate Cutoff and their Glue Line Rip blade.
Many people swear by the WWII, but I will never buy another Forest blade again. The Freud blade cuts through 8/4 like butter. My TS3650 acts like a totally different saw now. The Forest blades generates an annoying high pitch whine, where the Freud’s are unbelievably quiet. I was ripping with the CMT then running the edge on my joiner to clean it up. I have eliminated this step with the Freud glue line rip blade. I
go straight from the saw to the glue clamps now. When I cross cut the ripped glue ups, the edges are razor sharp making the second glue up process for the end grain board a snap.
I had a similar experience a few years ago with the Forest double sided melamine blade. I cut a lot of melamine for my custom closet business and I found the Freud to cut cleaner and is far less noisy than the Forest version.
There are a lot of different blades out there, and I have tried quite a few, but the Freud products seem to always work best for my saw. By the way, Tony made a good point, if your fence is off a little, no blade is going to fix that problem. Make sure your alignment is good.
-- I don't make mistakes, only design changes....
View Bigbuck's profile
Bigbuck
1044 posts in 200 days
143 days ago
I have the same saw and have been using a rip blade (dewalt) to resaw 3 inch thick walnut and haven’t had any problems with it boging down. I think I would try a ripping blade and if youstill had problems check the motor. Good luck.
-- Glenn, New Mexico
Scott Wilson
143 days ago
Thanks guys. I’m going to get a good rip blade and try that out after I double check the fence and blade alignment and see what that does.
Llarian
143 days ago
Its worth noting that the stock splitter on the TS3650 is for thin kerf blades. I haven’t found an aftermarket splitter that I like and would work easily on the 3650 that is full kerf yet, so I’m definitely sticking to TK blades for the time being.
I also use a combination of a Freud rip and a freud cutoff blade rather than a combo, I tried a WWII TK so I didn’t have to change blades so frequently since its more of a pain than on my RAS and just wasn’t happy with the results compared to the more purpose built blades I had for my RAS.
teenagewoodworker
2135 posts in 305 days
143 days ago
not sure what the problem is. i have a 1 1/2 hp jet table saw and a ryobi 10” 24 tooth blade (it was the only one i had when i bought the saw used, it had an hss blade). it went through 1 1/2” prupleheart really well. i think you might just have too many teeth there. when you get burns you usually have too many teeth. i would try a rougher more aggressive rip blade.
Bookmark And Share This Page
