I need some project help.
Forum topic by TrBlu posted 06-25-2012 11:07 AM 881 views 0 times favorited 7 replies Add to Favorites Watch
View TrBlu's profile
TrBlu
386 posts in 2622 days
06-25-2012 11:07 AM
Topic tags/keywords: walnut padauk maple lathe router
I am working on a project that includes Walnut, Maple and Padauk glued tightly together. There is a lot of router work and sanding involved.
The routing has deposited some of the Padauk and Walnut dust in the grain of the Maple.
How can I life the colored dust out of the Maple, so the Maples true features show?
Also, what do I need to do to sand this project without driving more of the Padauk dust in the Maple?
I think the project will finish well, if I can keep the colors from running together.
Thanks in advance for your help.
Tim
-- The more I work with wood the more I recognize only God can make something as beautiful as a tree. I hope my humble attempts at this craft do justice by His masterpiece. -- Tim
7 replies so far
View Woodworker_Collins's profile
Woodworker_Collins
195 posts in 2511 days
#1 posted 06-25-2012 11:16 AM
Im not sure how you could take the dust out but to stop more from getting in you could try pore filling the maple
-- Adam, Ireland, http://www.youtube.com/user/AdamTheWoodworker
View Tennessee's profile
Tennessee
2873 posts in 2511 days
#2 posted 06-25-2012 04:55 PM
I’ve had that happen with some of my guitars. Usually, a light wipe with lacquer thinner on a rag takes it off. Not a big deal.
View waho6o9's profile
waho6o9
8189 posts in 2573 days
#3 posted 06-25-2012 05:00 PM
Air hose at an angle?
13603 posts in 3337 days
#4 posted 06-25-2012 05:03 PM
tennessee got it
that’s what i do
16274 posts in 4214 days
#5 posted 06-25-2012 05:05 PM
In addition to the above suggestions, you can also try vacuuming.
View DS's profile
DS
2917 posts in 2417 days
#6 posted 06-25-2012 06:01 PM
Would scraping have this same problem?
View HalDougherty's profile
HalDougherty
1820 posts in 3233 days
#7 posted 06-25-2012 06:19 PM
The dust is noticeable when sanding with rougher grit, as you go to finer grit, the maple doesn’t have pores like walnut, and there’s nowhere for the colored dust to collect as the scratches from the sandpaper get smaller. After you pass 320 grit, there’s not going to be any color in the maple. After I start using 320 and finer grit, I use wet or dry paper that’s sold at auto parts stores for use on paint and wet sand with pure tung oil, thinned 50-50 with thinner.
-- Hal, Tennessee http://www.first285.com
