A tale of three handplanes
« back to Hand Tools forum
Forum topic by bandit571 posted 06-24-2012 03:11 PM 1276 views 0 times favorited 4 replies Add to Favorites Watch
View bandit571's profile
bandit571
19946 posts in 2676 days
06-24-2012 03:11 PM
Topic tags/keywords: question plane refurbishing sharpening
Two from a yard sale, one from a auction. The Auction Plane is just a Stanley #120. It needed a new cap, so I went back and got one. Might need a new iron as well. Clean him up, paint him nice and shiny, and back to work.
Plane #2: Same size as the Stanley #120, but a few things were quite different on this plane. For one thing, one strange looking iron:
Might be made by Sargent? Ever see a block plane iron with a cambered edge? There is a stamp on the iron as well. A large diamond shaped one. So, the iron says Diamond Edge. The cap was another matter, took a while to get it loose…
Needed a 5/32” allen wrench to get it loose. Under this cap…
Look Ma, no wheel! How would you adjust this then? It does have something the Stanley 120 doesn’t..
A bolted on knob! needs a bit of re-finish. So, a Scrub plane, in a Block plane size, with no adjustor wheel.
Third plane: Also a mystery plane. No makers marks, other than a “5” under the cap. The knob on this one is a fancy one, though..
Almost like it’s bigger relatives? It does have a wheel to tighten things down with, though
Just a might smaller than most. The iron is only 1-1/2” wide, the base is just under 6-1/2” long. The edge is different as well..
Not a camber, this time. A “toothing” blade? No marks have been found on this iron, as to who made it.
As for that 120”s iron, it IS marked for a Stanley. Instead of the clipped box, or the diamond shaped, or even the sweetheart shaped logo, this one has the STANLEY RULE & LEVEL Co. stamped around the rounded end of the iron. Across the bottom of this “arch” logo is MADE IN USA ( I think, still trying to bring it back out), so IF someone knows what it should look like, let me know. Three little planes…..
View bhog's profile
bhog
2236 posts in 2683 days
#1 posted 06-24-2012 04:09 PM
Good stuff Bandito.
-- I don't drive a Prius.
View BobE's profile
BobE
28 posts in 2945 days
#2 posted 06-24-2012 05:02 PM
The first plane you have pictured looks a lot like my Sargent 107
Just a guess, but they might have cambered the iron to use it as a small smoother. It’s probably got about the same footprint as a stanley #2.
bandit571
#3 posted 06-24-2012 07:04 PM
The two from the yard sale seem to work just fine. The Sargent clone worked without even a trip over the stones
As for “Shorty”, a few swipes on some flat sandpaper and away he went…
As for that Stanley #120? Going to take a lot of sharpening to get it as good as these two..
View Don W's profile
Don W
18707 posts in 2561 days
#4 posted 06-24-2012 09:52 PM
