Will contact cement adhere to Melamine?
Forum topic by MT_Stringer posted 06-23-2012 08:07 PM 5538 views 0 times favorited 3 replies Add to Favorites Watch
View MT_Stringer's profile
MT_Stringer
3153 posts in 3135 days
06-23-2012 08:07 PM
Can I get some quick advice?
I need to add a piece of MD to the bottom side of my router table, which is made out of melamine. Will contact cement bond the two pieces together?
I don’t have any scrap melamine to test.
Thanks in advance.
Mike
3 replies so far
View OldLarry's profile
OldLarry
18 posts in 2067 days
#1 posted 06-23-2012 08:16 PM
I’m not sure what MD is but if it is porous use melamine glue (Franklin’s or Roo.) If you resort to contact be sure to scuff the melamine surface well before hand.
-- Larry, Nebraska
View willie's profile
willie
533 posts in 2358 days
#2 posted 06-23-2012 08:17 PM
If you take some 100 grit sandpaper and rough up the area of the melamine that you plan to glue, it should hold up. Make sure you have good contact between the two pieces and if possible, clamp or put weight on it overnight. I’m assuming that you are talking about MDF and that this is to stiffen the table and not a way to mount your router.
-- Every day above ground is a good day!!!
MT_Stringer
#3 posted 06-23-2012 08:34 PM
Thanks fellas.
I just finished roughing up the melamine with a 4 inch grinder. Sorry about the typo. It is 1/2 inch MDF that I am attaching to 3/4 inch melamine.
The problem is the melamine isn’t thick enough for me to mount a combo track. I have four pieces of the MDF cut that will basically surround the router insert, just not crowd it so I can still make adjustments if necessary. My router table is just that, a table – nothing else. I clamp it to a B&D Workmate.
Thanks again for the quick responses.
